Reaming out holes in thick steel?
   / Reaming out holes in thick steel? #41
About the cleanest tractor I've seen on here in a long time.. Most are cruddy and loaded with filth. Myself, I don't like getting greasy from the grease hanging all over a unit if I don't have to...
I was always under the impression that bi-metal hole saws are only for light gauge materials (I have a set of Blu-Mol's myself), but for thick steel hole drilling I use my Mag drill and a Roto-broach bit. Not cheap but not a wrist breaker either.
I love my Roto Broach kit. I just bored CAT III holes for my homemade Landplane style blade I'm building. Bored the holes in 1" material. Drilled a pilot hole through, bored half the hole and flipped it to bore the other half. But I'm pretty sure you couldn't use them for this application without doing something sililar to what was mentioned above.
   / Reaming out holes in thick steel? #42
That's interesting. Unless the smaller saw protruded beyond the larger saw to act as a pilot, I guess the path of least resistance for the combined saws would keep them on center?
My aggravating tablet won't paste a compete link.
I found several presentations of how to center the larger saw by putting "Centering hole saw in large hole" into the YouTube search box. AVE did his enlargemet in metal and told what to do if the larger saw had a larger arbor.
   / Reaming out holes in thick steel? #43
Bought my mag drill used on CL a few years ago and grabbed the broach kit on MSC while it was on sale.
   / Reaming out holes in thick steel? #44
How do you stay true center with the hole saw w/o use of a pilot hole? I remember somebody on youtube showing a neat trick for that, but don't recall exactly what he did.
Sberry's picture in post # 31 shows one way that I have used. Clamp the right size hole over the too small hole:
   / Reaming out holes in thick steel? #45
Maybe this is it. He did get the inner saw to stick out.
   / Reaming out holes in thick steel? #46
There is a mandrel kit available for centering a larger hole saw on a smaller existing hole.
   / Reaming out holes in thick steel? #48
I've done that. (sberry Post #31) You can even use a scrap of 1/2" plywood for the template. It also enables you to change the location of the center of the hole if needed by clamping the template where you want it.
   / Reaming out holes in thick steel? #49
Another trick I've used (may not be possible depending on accessibility) -
if there's room -
1 - Drill a 1/4" hole in a piece of scrap material - this will be clamped BEHIND the material (but not yet)
2 - Set up the ORIGINAL size hole saw in its arbor but don't put it in the drill yet
3 - REMOVE the pilot drill bit from the hole saw - REPLACE it with a piece of 1/4" drill rod or possibly a VERY long 1/4" bolt with the head cut off; also cut off the threaded part. This will minimise the (no longer there) flutes of the (no longer there) pilot drill bit.
4 - Hold the scrap piece up against the hole to be enlarged, insert the protruding 1/4" rod in the hole you drilled - slide the backing piece around until the OLD size hole saw slips into the OLD size hole (the one you're going to enlarge)
5 - Now clamp the backing plate FIRMLY in place - then REMOVE the hole saw from the old hole and replace the hole saw with the NEW size one (KEEP the 1/4" smooth pilot ROD - BTW, you'll thank yourself for putting a SLIGHT taper on the end of the pilot rod)...
6 - Finally, mount the LARGER hole saw on the arbor with the SMOOTH 1/4" pilot, making sure the pilot rod is LONG ENOUGH to engage the pilot hole in your scrap piece; then mount the hole saw in your drill and enlarge the hole - if you follow ALL the above steps, it should result in a clean/larger hole that is on the SAME CENTER as the original hole. It also keeps an even load on the hole saw, and lessens the chance of wandering/jumping around while (re)drilling.
7 - All proper PPE is assumed, especially eye/face protection - I've also found that a fairly competent HELPER keeping a stream of compressed air aimed at the hole saw's teeth can make hole saws last longer AND cut better.
Or, if you were ALREADY too impatient to have bothered to READ this, grab your "gas axe" or plasma and WING IT :rolleyes: ... Steve
   / Reaming out holes in thick steel? #50
Nice, yeh! I mean both using a smaller hole saw as guide, and also clamping on a sacrificial piece of wood or stock to have something for the drill bit to bite into...I believe that's what the fella did in the youtube thing I saw.
   / Reaming out holes in thick steel? #52
I have used the hole guide plates with hole saws without a pilot drill many times to bore holes in truck, implements ant tractor frames. Great for re-centering a worn hole with a bigger fastener. Sometimes so obstructive used impact wrench with extensions and universal joint to drive the holesaw.
MK Morris bimetal hole saws come in 9/16” and 5/8” for smaller fasteners. Use oil and air to clear chips and cool on thick metal.
Plasma cutter with templates cuts accurate holes. Trying to drill a plasma cut hole is hard on bits. Big drills cost big money. Best use a die grinder with carbide.
If I can get it to stick, a mag drill is wonderful. Milwaukee with adjusting base, variable forward and reverse. Love to drill and tap threads with it. Mine has 3/4” drill chuck so haven’t tried the rotobroaches yet.
   / Reaming out holes in thick steel? #53
die grinder with a carbide burr, just make sure to use even pressure all the way around or you'll end up with an egg.
   / Reaming out holes in thick steel? #54
I would advise renting a 1/2 or 3/4" Mag Drill, or invest in a Plasma cutter.
   / Reaming out holes in thick steel? #55
I want to enlarge four 13/16" holes in 1/2" thick steel to accept 7/8" pins. This on a piece of equipment so I have to use a hand drill. I happened to have a 15/16" black oxide bit, not too surprisingly that doesn't work at all. In 10 minutes I only penetrated about 1/8" in one hole. So I need to decide between buying an $80 construction reamer (high speed steel, manufacturer says it is OK for stainless) or pick up a 29/32" cobalt drill for under $50. I'm guessing the reamer would work better even though it is softer. Is that correct?
Can you switch to 13/16" pins?
   / Reaming out holes in thick steel? #56
Cobalt will do the job.
A common mistake people make is checking the progress of the drilling by pulling the bit out. Due to the heat created by the drilling one can actually harden the steel if they stop midway through.
Use cutting fluid while drilling to cool the metal and lubricate the drilling.
   / Reaming out holes in thick steel? #57
How about a big-a** rat-tail file? You only have to remove 1/32" all the way around. I'd buy the biggest, coarsest round file that will fit into the hole, and start filing.
   / Reaming out holes in thick steel? #58
If not a round file, how about an aluminum oxide tool for a Dremel motor tool? That ought to remove a lot of steel quickly.
   / Reaming out holes in thick steel? #59
This will sound a bit odd but dull the drill a little. you can stone the cutting edge of the drill so it will not grab... Also if you can make some sort of drill bushing you can clamp to the outside of the of the part so you can hold it at 90 degrees. The trill pushing will also hold you on location.
If all else fails a bur and a reamer is a way to get it done...
I use a mag drill and dull the drill slightly so it will not grab and self feed. I hope some of this ramblings will help you!
   / Reaming out holes in thick steel? #60
This is a difficult one unless you have a powerful drilling machine. Ideally, you should use a drill bit to remove so much metal in conjunction with a low speed, powerful, two handed drilling machine. An HSS reamer is intended for finishing, not for removing a fair bit of metal. You don't say how accessible the hole is for you to hold the drilling machine. My recommendation would be to use a drill bit held very firmly, braced if possible, as this is going to jam when you break through the other end unless you have plenty of torque and a very firm grip.
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
Blue Diamond 103709 (A53317)
Blue Diamond...
