FatTire
- Joined
- Oct 2, 2007
- Messages
- 1,371
- Location
- Colorado
- Tractor
- Kubota L5740, Unimog 404 w/ snowblower, Deere 620i UTV, MX5100 (sold)
I just did this in some 1/2" A36 steel.
I up sized 13/16" holes to fit 7/8" pins.
You can buy a 3/4" "drum sander kit" from ACE hdwr.
ACE item # 2495083.
An even better option is to buy the little drum discs from McMaster Carr.
Their little drum discs are much higher quality than ACE, last twice as long, and are not very expensive.
I bought 10 from them for about $12, still have 6 left.
The McMaster Car package description is: "Spiral No-Lap Band"
I bought 80 grit.
If you go to their website, you will find virtually every size and type you could possibly want
That's something I didn't even think of. I would have guessed it would take forever to remove enough material, but apparently not.
I am using a variable speed AC powered drill but the angle grinder is a good option too. Thanks everyone for the suggestions-- the holes were cut originally with a plasma cutter, they're pretty good but it is obvious how they were done. This isn't critical, it is for a 3 point hitch mount, apparently the holes were for 3/4" pins but this is a heavy attachment -- I will feel better with 7/8 pins. I'll post again when I'm done with some photos.
