Mowing PTO plastic guard
/ PTO plastic guard #1
Acethe3rd
Mahindra 1533
Hello. I know this has been talked about on here before but here goes. Anyone have a clue as to get this off without cutting it off? I have pushed, pulled, read, watched, basically looked everywhere. I can’t get it off.
/ PTO plastic guard #2
flat blade screwdriver to push in the white plastic tabs?
/ PTO plastic guard #3
I'll agree with the screwdriver pressure assessment. You'll have to push both sides in at the same time so it will probably take s second person. Those things arre NOT easy to pull back by design.
/ PTO plastic guard
Thank you. Yes, I have done that. I have about reached my limit. lol
/ PTO plastic guard
That is the truth. This one has baffled me. About to go back out and try it again. Thank you.
/ PTO plastic guard
Had one that was 3 little screws. And the collar rotated so re-aligning the holes back up was super duper fun..
lol No screws. I kept thinking I was missing the screw. Nope. Notta. None. This one is hateful.
/ PTO plastic guard
The good (??) news is that it will probably fall apart on its own after a few uses.
Thank you. I needed good news after fighting this. Back to it in the morning. It is coming off!
/ PTO plastic guard
I was using too many farm words. Back at it tomorrow. Thank you.
/ PTO plastic guard #14
Ace-did you get it off?
/ PTO plastic guard #16
I know you are supposed to maintain the guards for safety, but as dangerous as pto shafts are I think the best rule is to not get around it while it's running. I also don't understand why a replacement guard costs over $100, they want people to use them they need to make them reasonably priced
/ PTO plastic guard #17
I’ve seen them on their website but can’t find anyplace to actually buy them. Any leads?
Type in your zip code (Place Order link)
/ PTO plastic guard #18
I have always heard those things called "Bippie's" and they can be a pain to deal with, as you have found. I understand their use, but when a rotary cutter doesn't have one, I don't go looking for one to put on it!
A sawzall might a little bit of mistake, but I bet you have thought about it a time or two!!
Hope you get it off soon!
David from jax
/ PTO plastic guard #19
If you want to keep the guard on it swap it out for one from Bare-Co.
Bare Co USA - PTO Select Safety Guards
these guards are easy to release and retract and reconnect
I have three of these safety guards and love them. They make it so easy to connect to the tractor. Flip up the levers, slide the cover back, put on the pto shaft, slide the cover back into place and snap the levers back in place.
/ PTO plastic guard #20
So how much did these covers cost? I like the idea of not having to fight the cover being in the way while trying to hook up PTO shaft, they are a pain enough.
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2014 Chevrolet Tahoe SUV (A64557)
2014 Chevrolet...
SHOPBUILT S/A TRAILER FRAME (A64278)
SHOPBUILT S/A...
2004 Harmon Steel Barrel Asphalt Tanker Trailer (A64194)
2004 Harmon Steel...
2018 Chevrolet Silverado 3500 Royal Service Truck (A64194)
2018 Chevrolet...
