Reaming out holes in thick steel?
   / Reaming out holes in thick steel? #1
FatTire
Colorado
Kubota L5740, Unimog 404 w/ snowblower, Deere 620i UTV, MX5100 (sold)
I want to enlarge four 13/16" holes in 1/2" thick steel to accept 7/8" pins. This on a piece of equipment so I have to use a hand drill. I happened to have a 15/16" black oxide bit, not too surprisingly that doesn't work at all. In 10 minutes I only penetrated about 1/8" in one hole. So I need to decide between buying an $80 construction reamer (high speed steel, manufacturer says it is OK for stainless) or pick up a 29/32" cobalt drill for under $50. I'm guessing the reamer would work better even though it is softer. Is that correct?
   / Reaming out holes in thick steel? #2
Cobalt drills are harder than high speed steel, but brittle, and tend to chip if setups are shaky, like with hand held drilling. HSS reamer might work better, if you're not taking too much out. I'd finish the hole you started on last, in case it's been work hardened.
Did you resharpen your 15/16?
   / Reaming out holes in thick steel? #3
Reamer would be lot better, using a bitt you're going to either break it, break your wrist, burn out your drill or jamb your fingers. Get a three flute tapered reamer. If you're not fussy about being perfectly true, use a carbide burr..........Mike
Thanks. The 15/16 was basically new, I used it for one project drilling some thin aluminum, just a couple of holes.
On my first attempt I thought my wrist would be wrecked a few seconds before the drill burned out.
   / Reaming out holes in thick steel? #7
That's a tricky thing to do when you can't vise it down in a drill press. Any chance you can use bushings instead? I'm not sure of your application but I think I know what you are trying to do.
   / Reaming out holes in thick steel? #9
I'd use my fire wrench with a washer template on both sides. If these are for lift link pins, don't they have a shoulder on them to hide your artwork ?
   / Reaming out holes in thick steel? #10
It's amazing what a good cut I can get with my plasma cutter with a guide template. Problem is, you have to have a plasma machine.
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
500BBL WHEELED...
Mini Skid 6 Way Blade (A56436)
Mini Skid 6 Way...
2020 DRAGON ESP...
(APPROX. 20) 4' X...
