Troy-Bilt Horse-1, Tecumseh 8hp Air Filter Replacement
/ Troy-Bilt Horse-1, Tecumseh 8hp Air Filter Replacement #1
Denwa
Blaine WA
Kubota B20
Got the above at an auction. The air filter that was in the vertical chromed can was a total mess and not a proper replacement. From looking a the owners info it seems that the tiller originally came with a foam w/ oil filter.
I hope to replace the mess that was on the tiller with an appropriate paper air filter. Will someone please tell me what air filter replacements (brand/model) have worked for them.
/ Troy-Bilt Horse-1, Tecumseh 8hp Air Filter Replacement #2
Try jackssmall engine parts with a model number from the engine.
/ Troy-Bilt Horse-1, Tecumseh 8hp Air Filter Replacement #3
Here's couple of manuals that can be found online & should help you identifying what you need.
Are you sure it's Horse with 8 hp Tecumseh engine?
I thought they were using 6 hp Tecumseh, 7 hp Kohler and 8 hp Briggs engines.
  • Troy Bilt Horse 1 and 2 Parts Manual.pdf
  • Tecumseh_Engine_Manual.pdf
Thanks for the manuals, I'll see if they shed any light. I called T_B tech and from my serial number and FWIW the gal definitively ID'd my tiller as a Horse1. After looking at the offered Horse 1 manual she sent, I was indeed confused by the 6 and 7 HP being the only options mentioned and in list chatter on engine replacement, the 8HP option was somehow not approved for the older Horse1. ??? Something to do with the metal the tranny was made from?
Anyhow, the Kleen-Aire filter that came on my unit was apparently a oil soaked foam thing, and I was hoping to get a modern paper filter to replace it. No luck finding anything that fits so far at auto parts stores. Perhaps the old oil soaked foam would be superior to a paper filter? No experience with that old tech, but it would be messy for sure. In that my tiller does not look to be set up like what is pictured in the manuals I've seen so far, I'm not sure zactly what model I've got. I've got 8HP Tecumseh with black plastic gas tank mounted level with top on port side of engine, Kleen-Aire filter on opposite side of engine. The filter has a chromed cover with a wing nut on top. Muffler is not a straight out one, but is rather built in a dog-leg shape with the exit hole above and to the rear of the actual exhaust port. Further research is obviously needed ...... Still hoping some list member has already sussed this out and can shed light. I'll report back if I get any good data from T_B itself.
DW
/ Troy-Bilt Horse-1, Tecumseh 8hp Air Filter Replacement #5
On my 70's model Craftsman walk behind, front tines rototiller, is the Briggs 8 HP engine. And it has the oil soaked foam air filter. It still works fine even to this day. I just service it or replace it every ten years or so.
Cheers,
Mike
Cheers,
Mike
Good to know. An oil soaked foam has got to be effective and simple technology. Likely just to messy for folks when given the option of a paper element. I finally got what looks to be the proper part number for what I need. Unfortunately it is unobtanium locally and I'll have to order. For MY setup it's Tecumseh #34700. O'Rielly has what looks to have a compatible unit, #7-02719. Having issues with the big A right now and can't get images of the filters offered, but there seems to be possibilities there too.
/ Troy-Bilt Horse-1, Tecumseh 8hp Air Filter Replacement #7
Sounds like you are on the right track. But I recently found a site (www.fix.com) that gave me good service/parts on an old snow blower. The service was good.
Cheers,
Mike
Cheers,
Mike
Looked at the site, thanks, and they list a couple of filter options, but as with anywhere else I've seen something listed, there is not picture, measurements or description beyond "it fits". Must be pornographic or something ;' > Have to call ....
/ Troy-Bilt Horse-1, Tecumseh 8hp Air Filter Replacement #9
I have a 8hp Briggs (from the 70's) on a Chipper Shredder. It used a oil soaked filter that self destructed when i went to take it off (probably never removed and cleaned ever). I ended up taking the housing to the local Lawn and garden shop and asking what they had on the shelf back there that might work. After some trial and error fittings I ended up with a paper filter that worked. No idea what the part number was or is but you might have the same success by that as well. You just need a parts counter person who isn't crazy busy and will spend some time with you.
If I cold see what I was ordering on the big A I might have gone that way, but failing that I put an order in online from O'Reilly's for what is a part number match to what I got from T-B itself, 34700. We shall see.... The dimensions are about right for my setup, whichever actual iteration of the horse-1 I have.
2013 Ram 5500 Bucket Truck, VIN # 3C7WRNALXDG552597 (A61165)
2013 Ram 5500...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
