Mowing Kubota diesel overheating.
/ Kubota diesel overheating. #81
Try this first before any thing else, most important, fit a brand new radiator cap make dead sure it's for that particular engine, Why you might ask? The radiator cap has a pressure rating on it which puts the whole system under pressure resulting in a higher boiling point, above 100c,"if it's faulty it will boil at 100c" it's also a safety valve.
hears where your thermostat comes in to play it dose two things first it gets the engine up to its optimum running temp second it regulates the speed the water is pumped around the block and through the radiator, the thermostat has a set temp stamped or engraved on it some where that's around the optimum running temp and should only be replaced with the engine manufacturers recommended rating the radiator cap is often overlooked or ignored but these two items work reliant on each other.
Never run a diesel motor without the thermostat, more so if it has an alloy head removing the thermostat can result in the water going through the system to fast to cool down even with the fan going and boiling, in some cases where there is a giant radiator it may never get to running temp resulting in rapid engine wear.
Belts and pulleys are another issue Plastic pulleys are most likely to cause slipping as are some thin pressed metal pulleys they wear or spread apart causing slippage on the fan.
Radiator caps and thermostats are cheap, throw them out if in doubt replace them with genuine parts.
Also check your Hydraulic oil level if you have a hydraulic oil cooler built in to your radiator it could be the cause of your radiator boiling, I have had this happen on my Cat back hoe after bursting a hose and loosing 3/4 of the hydraulic oil then trying to use the loader bucket to finish a job. In this case the radiator keeps the hydraulic oil at its working temp all year round.
/ Kubota diesel overheating. #82
I have a kubota diesel RTV 1100. My experience with this machine has been extensive, I'm on my third head, and second radiator. the original head and the one after that the heads cracked from getting hot, I noticed when i pulled the head off the first time how small the water jacket ports were and 2 were clogged. I cleaned them with a tooth pick. The ports are around the cylinder fartherist from the water pump and fan. When it got hot with the original head i added some granular stop leak thinking i had a radiator leak, in hind sight that's an absolute no- no, i should have used something like Zerex. Now I'm going to try removing the radiator turning it upside down and flush it with a pro grade air/water combination gun. The next thing I'm going to do is flush the engine/ water jacket with the same air/ water gun. The flush to both will be in reverse of the coolant flow of the engine/ radiator combination. If i have to replace the head again I'll drill those coolant ports bigger before installing the new head. Also make sure your air filters are clean, an engine that can't breath properly has to work harder and therefore generates more heat. Kubota must know about this problem. The temp sending unit is on the head directly above the cylinder with the two small water jacket ports. There's 3 temp sending units, one controls the electric fan on my machine, one sends the signal to my temp gauge, and the third i have yet to learn its purpose. Good luck to you buddy.
/ Kubota diesel overheating. #83
Well over half of the diesel engines in existence have no thermostat. Especially on industrial engines, it has very little impact or need, they do not utilize a bypass.
/ Kubota diesel overheating. #84
I’ve got a grasshopper ZT with a Kubota diesel in it. It happens fairly slowly but the temp keeps creeping up. The radiator is clean. The air filter is clean, the fan belt is tight, the fan shroud is in place all but a little bit at the bottom which I don’t think has ever been there. There’s no fan clutch, it’s direct mounted. I’ve taken the thermostat out and ran without it and there’s no change. I put the thermostat in a pot of water and heated it on the stove and the pot was very near boiling before it opened. I honestly thought it would fix the problem taking that out but it didn’t. I might repeat that that test with a thermometer since it was supposed to open at 160 degrees. I’ve taken the side panels and hood off to see if better ventilation would help and it does but not a notable amount. And it blows more heat down my back that way. The radiator is as hot as the block when checked with an infrared thermometer. So it seems to me the radiator is taking heat but not loosing it. I’m pretty much at a loss on this one.
Exactly what model is this Kubota zero turn diesel mower you have ?
i have a Kubota ZD21 with a little over 1,200 hours, in hot weather the temperature gauge has alway ran close to the red zone but so far it has never overheated at least not that I’m aware of, I have always removed the covers-screens when done mowing to blow off any debris with a leaf blower. Changed the antifreeze about 5 years ago and I will only use premixed antifreeze in everything I own, guess it’s about time to change the antifreeze again.
But after reading this thread I am definitely considering applying Some kind cleaner to the outside of the radiator when it’s cold and let it soak awhile before washing it off with a garden garden hose, I have done that with some other radiators and always been surprised at the amount of stuff that comes out.
/ Kubota diesel overheating. #85
"Well over half of the diesel engines in existence have no thermostat."
Where did you get that information?
/ Kubota diesel overheating. #86
Could be you are running lean on fuel. Most any motor will run hot after a bit if it does not get enough fuel.
Lean mixture overheating applies to gas spark ignition engines, not diesels. Diesels run over a wide range of fuel to air ratios but gas SI engine have to operate within a relatively narrow range of fuel to air ratios and depend on charge cooling from the fuel to keep peak temperatures within a certain range.
The radiator isn’t boiling over. It’s holding as designed. The radiator is just that, no other built on coolers. The sending unit for the temp gauge is correct verified with in infrared thermometer.
/ Kubota diesel overheating. #88
If the thermostat is out, the radiator is not clogged, and the fan has its blades and spins when running (loose belts), it points to a water pump that the impeller may be slipping or have a shear pin that has been sheared or more likely the belt is broken/missing or too loose.
If the system is at least reasonably clean, the fan turns, and the thermostat is out, it is almost surely the water pump impeller or belt preventing the coolant from circulating.
Dane…
/ Kubota diesel overheating. #89
Water pump checked yet.
replace the radiator cap. take off that front grill...dont get enough air thru them tiny holes. i made a grill for mine with hundreds of 1/4 inch holes. problem went away..even in hot summer days. i run 50 50 coolant.
/ Kubota diesel overheating. #90
Salvage yards, military surplus, shipment manifests, etc.
Could pull serial numbers for 3 cyl Yanmar, Mitsubishi, and Kubota engines used in generators, reefers, waterpump stations, mairine drives, etc. There are also many 1 and 2 cylinder air cooled diesels out there as well.
Or we could run numbers historically:
The good ol' original peanut oil versions certainly had no thermostat. The thermostat was invented in 1934, prior to then no diesel engine had them.
Thermostats and bypass are very important for 4+ cylinders, where the issues you highlighted are a factor.
Dane…
The water pump is good. In this picture it’s got a water hose hooked up but it emptied the radiator at the same or faster rate on its own.
It’s a grasshopper 428d with a Kubota diesel.
/ Kubota diesel overheating. #93
besides what you have done already, make sure the belt isnt slipping, check for a combustion leak into the cooling system, also pull the water pump and verify the impeller is in good condition. take the radiator to a shop , have them pull one tank and rod the tubes. even though it seems like it has good flow there maybe enough tubes clogged to cause the overheat.
/ Kubota diesel overheating. #94
Have you considered a leak either in the head gasket, the seals between a cylindar and the block. Try using a sealer. You might have a leak so small it's undetectable in the exhaust. You've also indicated it seems to gert hotter with time, indicating engine expansion is expanding the leak. https://www.google.com/search?q=eng...ome.1.0l10.20939j0j7&sourceid=chrome&ie=UTF-8
/ Kubota diesel overheating. #97
I know you have probably checked this but I'll mention it anyway..
I had a similar overheating problem. Went to dealer and described it. He said "you been mowing grass?". I had been. He said, "Did you clean the grass off the removeable screen in the engine compartment?"
He was right. I cleaned it, the problem went away and I learned something.
Thought it might be worth mentioning.
I’ve temporarily removed the shrouds from the engine bay. It helped enough I can mow without the high temp light coming on but it didn’t do a lot.
/ Kubota diesel overheating. #99
One of the purposes of the thermostat is to keep the water/engine ect. at the recommended temp. It slows the flow of water through the radiator so that the coolant cools. If it goes thru too fast the coolant will continue to get hotter. You must have a thermostat to slow the water. I ran a dirt track car with a piece of aluminum with a 1/2" hole to slow the flow. It could be your thermostat is sticking too far open.
/ Kubota diesel overheating. #100
My quick thoughts. Many times, taking the thermostat out will allow too much circulation. Water moves too fast thru the radiator and cannot cool enough. Slow climb to overheating. As was mention somewhere in the first 10 responses, make sure you can see thru radiator fins. Having the fins look clean but having Dusty dirt between the fins will not allow air to pass thru. Blow water in the opposite direction that the air passes thru. That's all I got.
2019 Toyota Mirai Sedan (A64557)
2019 Toyota Mirai...
2025 TEXAS PRIDE 14FT T/A DUMP TRAILER (A59914)
2025 TEXAS PRIDE...
2016 GMC Sierra 1500 Crew Cab Pickup Truck (A64556)
2016 GMC Sierra...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
