Homemade, prefab, concrete and pine post
   / Homemade, prefab, concrete and pine post #1
rbstern
GA
LS MT225E, Yanmar 2210
Prefab pole barn posts with a concrete base seem to be gaining in popularity (see image below for reference).
With building material so scarce and prices so high right now, I've delayed my pole barn build. It's not a must have, so it can wait. But I'm also thinking I could use the delay time productively, and cut my own posts on my saw mill. The issue for use in a build, obviously: Not treated lumber.
I was thinking of cutting 6" true posts, drilling the base of the pine vertically for a piece of 1/2" x 4' rebar, leaving 3' of the rebar exposed. Then, I would attach a concrete pouring form, 6"x6"x42", to the bottom of the post and pour in standard, 4000psi Quikcreate or Sakcrete. The rebar would be center-suspended in that mix and provide both lateral and vertical adhesion between the concrete and the post, and keep the pine off the ground when placed in the post hole.
Thoughts? Any reason that can't work?
iu
   / Homemade, prefab, concrete and pine post #4
How would that provide any vertical adhesion? It would keep the post form sliding horizontally, but what would keep it from lifting off the rebar?
What is your thought with the rebar?
What is it's purpose?
Threefold:
Resist lateral loads
Resist vertical loads (the rebar is hammered in snugly, with some construction adhesive in the hole)
Reinforce the concrete
Why not just use something like this sturdi wall plus?
Budget build.
For the price of one of those, I'm 85% of the way to a 16' 6x6 PT post, or halfway to the cost of a 20' 6x6 PT post, which I can use in a traditional, in-ground install, and the barn will likely last longer than I will.
I do love the looks of those, though.
If you've ever hammered 1/2" rebar into a 1/2" hole (with a sledgehammer)...it takes a lot of force to drive in. Would also add adhesive to the hole.
   / Homemade, prefab, concrete and pine post #8
Threefold:
I'd be very surprised if rebar pounded into a wooden hole with adhesive were an accepted practice by code because the load pulls with the grain, not across it like bolts through brackets. Think about it. If you drive a nail into end grain, it is very easy to remove. If you drive it across the grain, it is less easy to remove. Maybe it's acceptable? I do not know. I think I'd use the brackets. They add more strength.
   / Homemade, prefab, concrete and pine post #9
Budget build.
Budget build still requires sound practices.
I built a 24 x 24 garage addition last summer. After getting quotes for $6K on concrete I did it myself for half. Lumber, siding, roofing, fasteners etc., were $5K and I did all that myself as well. It was a budget build. I still had to follow code and sound building practices. Some things you can't skimp on.
It might be 'good enough'. I wouldn't do it.
   / Homemade, prefab, concrete and pine post #10
I did it the other way around. Set the rebar into the concrete first and let it set a few days. Then drilled the posts and lifted them into place. Used a smaller piece of steel strapping as brackets.
These were only 4 x 4 x 8 posts though and it's only for a shed roof/awning. And I only came an inch or s above ground. And I don't have any codes, permits or inspections to deal with.
BOBCAT E45 EXCAVATOR (A52706)
BOBCAT E45...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2005 IC Corporation PB105 School Bus (A55852)
2005 IC...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
Self Dumping Hopper (A53316)
Self Dumping...
