Stuck loader arm, ASV RC-100
/ Stuck loader arm, ASV RC-100 #1
aronh89
ASV RC-100
Does anyone know how to manually lower the loader arm on an ASV RC-100?
If the loader arm is raised when the machine is turned off, you can’t restart the machine because the startup sequence requires the loader arm to be down before cranking.
I have scoured the internet but cannot find this info. Thanks to anyone who can help!
/ Stuck loader arm, ASV RC-100 #2
I had same problem with a CAT tracked skid steer. I turned the key to “on” and wiggled the pilot controls on the loader and it slowly worked its way down.
Thanks!
/ Stuck loader arm, ASV RC-100 #4
Did it work?
/ Stuck loader arm, ASV RC-100 #6
I had a CAT skid steer on a steep hill, mulching a tree with the loader up about 8’ high. The motor stalled and the loader was blocking the door! Turns out the bank was steep enough to make the fuel pump suck air. I was stuck in the cab. Door blocked, 7pm and no help anywhere nearby.
Couldnt figure out what to do, so I turned the key on, wiggled the joy stick and the loader came down about 1” per wiggle.
2001 International 3800 School Bus (A64194)
2001 International...
2022 EZ-GO ELITE...
BUSH HOG 4R48" BEDDER (A64278)
BUSH HOG 4R48"...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
2018 CATERPILLAR CB10 DOUBLE DRUM ROLLER (A65053)
2018 CATERPILLAR...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
