Trick to keep quick connections locked together?
   / Trick to keep quick connections locked together? #1
Snowlan
Halifax, Nova Scotia
Bobcat CT2025
I’m new to having a tractor and have discovered quick connect hydraulics can come apart very easy. One of the hoses to the backhoe shifted while in use, the fitting was sitting on the PTO cover and the edge of the cover put enough pressure on the quick connect collar when it shifted that it popped open.
It was one of the return hoses and it damaged the backhoe control block with too much pressure on the used oil discharge side (three hose system).
Anyone have any tricks to guard the coupling collars and prevent accidental release?
   / Trick to keep quick connections locked together? #2
My take on hydraulic couplings is that I believe they are designed that way so that they will seperate in the event they need to, such as driving off with the hoses connected. I never have too much of an issue with them. Every now and then I won't get one coupled up completely and it will pop out when pressure is applied but once they are fully seated I have no issues. I would think if you are pulling one apart you may have a hose that is too short. It might be a good thing it did.
   / Trick to keep quick connections locked together? #3
They don’t pop off easily. Only if they are housed in a certain type of snap ring enclosed housing will they pop off off pulled on by the hose. I drove off without disconnecting my 400lb grapple once, and they just drug the grapple across the dirt until I disconnected them. You have issues if yours just pop off.
Lots of slack hose, as required to connect hoses before fully backing up tractor to connect backhoe. Used the backhoe all afternoon, next day, first move made on the backhoe popped the hose off (or popped off while driving tractor before the backhoe was used).
No tension on hose, just weight of hose and the coupling just happened to be sitting on a hard edge that could move the collar. Seems way to easy to me, so looking for a way to prevent it since it has put my backhoe out of service until valve parts are in stock. Don’t want that happening on a regular basis.
   / Trick to keep quick connections locked together? #5
This^
If there is pressure in the line (as there should be with the return line for a BH which is likely a constant flow) the fitting should be damn near impossible to get apart. Either you did not have it properly connected to begin with, the connectors are not identical/compatible, or you have a faulty connector.
You should also watch all your hoses anyway, there shouldn't be an instance where a hydraulic hose is moving while contact with anything stationary or vis versa because it always leads to larger problems.
   / Trick to keep quick connections locked together? #6
If the slip collar was resting on an edge when you shut the tractor down it could have released when the pressure was removed from the system and possibly disconnected as soon as you started the tractor without you noticing. Pretty unlikely IMHO.
Red and yellow hoses stayed connected which are the ones completing the loop. Blue hose which is the used oil return is the one that popped off and the pressure blew the cover off the valve on the back side of the main boom lever. Now moving any lever in any direction blows out out this leak.
Note the cap screws did not come if the holes, though they did get bent when the ears cracked on the cover. This was just me investigating to see if I can repair on site and what parts are needed.
   / Trick to keep quick connections locked together? #8
I would spend time looking over the qd that you say did this. There is something wrong with it.
   / Trick to keep quick connections locked together? #9
View attachment 700934View attachment 700935
Is that the oring poking out?
   / Trick to keep quick connections locked together? #10
Something is wrong. Connectors don’t just pop apart.
   / Trick to keep quick connections locked together? #11
To insure this does not happen again,, simply "T" in a relief valve in the return line,,
if the hose pops out again, the relief valve will dump.
Nothing will be damaged,, except a very small amount of oil.
Set the relief valve at some pressure above the system operating pressure.
You do not even need a gauge,, if the relief valve leaks in normal operation, adjust the valve for higher pressure.
Liquid is non-compressible,, that is good,, but, that can be bad, also,,
you happened to find one of the "bad" things about a liquid.
This is EXACTLY how a "RAM PUMP" works,,
The relief valve will be cheaper than looking for some quick connect solution,,
and you will be POSITIVE that your new valve will be protected.
Good catch, I believe it is. The question is, did the oring blow out because I tried to move hydraulics while the return line was disconnected?
Dealer is saying this probably won’t be warranty on day 2 of operation/ownership because the hose was off.
Problem with the other comment above about the hose shouldn’t be able to come off while pressurized - this is a 3 hose setup and this hose is not one that is always pressurized. The other two hoses make the loop, from my understanding this hose only has flow while a move is being made on the backhoe.
I have a hard time believing that a hydraulic system should be this vulnerable to damage when a hose comes off, what are other’s opinion on this?
   / Trick to keep quick connections locked together? #13
Absolutely the system is vulnerable,,
Very often, the hydraulic pump is destroyed when something like this occurs.
(You might want to have your pump checked, to make sure it is not also damaged)
The "three hose system" is power beyond,, you basically had a plug put in the power beyond port.
Some people put a plug in the power beyond port, not knowing a hose is needed.
They run into this exact situation,, something has to release,, in this case, it was your valve.
   / Trick to keep quick connections locked together? #14
Most likely immediate failure will be at the oring and easiest fix, if screws were bent it's probably going to be more significant though.
So I'm not sure how a three hose system works, with a two hose there is built in bypasses on most so you don't over pressure the system. If you need a third hose for return fluid then it's going straight back to the tank? If that's the case I guess it could potentially get knocked loose because it would only have pressure when there is flow but I'd still find it hard to believe it could get freed as you described.
Also sounds like your dealer needs a boot upside his head.
   / Trick to keep quick connections locked together? #15
Are you sure that nothing hit the collar on the fitting and released it?
   / Trick to keep quick connections locked together? #16
If you crash your Lamborghini into a pole on day two of ownership,, is it the dealers fault?
This was an accident,, and possibly caused by the person who installed the backhoe.
Improper routing of the hose may have caused this,, much like routing the car into the pole.
   / Trick to keep quick connections locked together? #17
It appears the return to tank line came off which will over- pressure the valve body, it will not deadhead the pump, the system/valve body relief will still be functional in this case.
It sounds like there isn't anything wrong with the QC other then being in the wrong place where it could get bumped. Since it's the tank return there won't be any pressure in that line while operating and will be easy to release.
I would look for a solution to keep the hoses in check, a velcro strap can be used to tie the hoses up and keep them from contacting something that might release the QC. Other option would be wrap the QC with something, or change out to Flat Face couplers which often have a smaller sleeve and a detent ball that has to be lined up in order to release.
   / Trick to keep quick connections locked together? #18
Maybe everyone missed it but he said the collar (on the female fitting) was resting on a ledge. The weight of the hose and driving the tractor (bouncing around) slid the coller back and the hose popped off. That ledge was acting like your hand when you pull the collar back to disconnect the backhoe.
The fix is secure your hoses (with zip ties or bungee cords) so that doesnt happen. Because they DONT just come apart on their own unless the collar is shifted like when disconnecting.
And yes.....with that hose uncoupled, it is very easy to blow the valve. The "tank" ports and passages are NOT designed for high pressure. And failure of the valve like you had is exactly what happens. Looks like you blew an o-ring out that seals the spool valve to the casting....that filled the can with oil. And 2500psi of oil inside that can does exactly what you pictured.
Note that no damage occurred until you attempted top move the backhoe's hydraulics without an open return path for the oil to get back to the tractor/tank.
   / Trick to keep quick connections locked together? #19
Not everyone
   / Trick to keep quick connections locked together? #20
I didn't either but I also didn't completely understand until I saw the pics that the couplers are not like a JD. Mine have no collar and are not that hard to release.
2008 FORD F-550XL SUPER DUTY INSULATED BUCKET TRUCK (A60430)
2008 FORD F-550XL...
2012 Freightliner Cascadia (A56438)
2012 Freightliner...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2018 BOBCAT E45 EXCAVATOR (A59823)
2018 BOBCAT E45...
iDrive TDS-2010H...
2018 Ford F-350 (A55973)
2018 Ford F-350...
