Another welder advice thread
/ Another welder advice thread #1
FTG-05
Elite Member
TN
Kubota L4330 GST w/FEL, Kubota RTV-XG850, Kubota ZD326S
As if we didn't need another "what to buy" welder, but unfortunately - I need your advice.
My Lincoln SP-175Plus MIG welder just bit the dust. I turned it on this afternoon and all I got out of it was a mild groan, then... nothing. I've had it since mid-1999, so I got my use out of it.
Hence, as I see it, I have three options:
A. Do without a welder (assumes I can't find a welder fixer or the Lincoln can't be fixed)
B. Find a half decent cheapy welder and use it as a bridge-gap welder until the Lincoln is fixed (assumes the Lincoln can and will be fixed at some point)
C. Upgrade to above a +SP-175 Plus-class welder i.e. something with quite a bit more capability.
Option A ain't happenin', sorry I won't live without a welder.
Option B is a HF special (Titanium?) or equivalent, something that will keep me welding until the Lincoln is back up and running. Obviously, this option is betting that the Lincoln can be fixed. If so, the cheapy becomes the Low End welder, while the Lincoln becomes the High End (read thicker) welder. Another problem is while I'm ok with a cheapy 120 VAC welder, I really don't want a 120 VAC Flux Core-only welder.
Option C is an upgrade over the Lincoln; if the Lincoln gets fixed, great it now becomes the .25" welding wire Low End welder; while the new one takes over the High End .35" duties.
Option B welders include the various HF products, although most of them are on back order, sort of defeating the purpose here. Everlast is an option, but their bottom of the line is more than I want to spend on a BOL welder.
Option C is looking better and better: I'm thinking a Miller 211 for $1500 or so. I wish I could spring for a Miller 255 but +$3K isn't in the cards. :(
So bottom line, two questions:
- Are there other options I'm missing?
- Alternatives to the mentioned Low End and High End welders and limits discussed above?
Thanks!
/ Another welder advice thread #2
Hobart Handler 190 if you don't need dual voltage (120/240) .... I have a Hobart Handler 140 its been good for 8 years and does 95% of my welding (120VAC machine), wished I had gotten the Hobart Handler 210MPV though...
/ Another welder advice thread #3
look on Craigslist or Face book marketplace for or a good deal on a 250 amp , they are there bought my Hobart 250 mig out of a hot rod shop that was closing down 650.00 cash . the color of the machine doesnt bother me as my field welder is Red and the shop welders are Blue ..
CL is an option but not a plan due to the scarcity of decent machines coupled with the flakiness of it's users. I don't use FB.
The Handler 180 is pretty close to the Lincoln SP-175 in terms of output etc. I'm looking for the extremes: either smaller or larger, not duplicate.
Now the Hobart IronMan 240 caught my eye. It represents a significant upgrade over the SP-175, Handler, 180 or 210 and the Miller 211.
Comments on Hobart quality?
/ Another welder advice thread #5
I have a Titanium MIG 175 that I got open box for super cheap, I've been trying to kill it and it just doesn't seem to care... I've ran it off a cheap Champion 4kw generator hard enough to stall the generator, ran it off a couple other generators, ran it on a GFI outlet that gave out while welding and put probably 15 pounds of flux core wire through it. It welds great, done everything I've asked of it...
That said, I've heard good things about Everlast too...
/ Another welder advice thread #6
The Hobart is super good and would be on my short list if I was in the market for this type of machine. Its full size, full chassis and holds big spool and big bottle and will repay its cost vs a smaller unit if used much. its 2x plus a 210 MVP compact.
I've heard good things about the HF Titanium welders. Unfortunately, their website says late Sept to mid-Oct before they ship on anything. :(
I have an Everlast 120 vac plasma cutter; I've had it for 3-4 years now. I wouldn't hesitate to buy another Everlast.
However, the problem with Everlast is that their higher end MIGs are all multi-process which I neither need nor want. The other problem is that their low end MIG welders are too expensive or too much performance for low end work or more than I want to pay.
I talked to my local professional welder this morning. He said Hobart was Miller without the frills and dressings. Otherwise a pretty good machine for a DIYer, hobbyist etc, not a professional or an industrial environment. I'm ok with that.
If I decide to upgrade, the Hobart Ironman 240 is on the short list. Unfortuantely, they are all on back order as well. NT says ships in 5-8 business days but I bet it's closer to 5-8 weeks. :(
/ Another welder advice thread #9
If you've had occasions when you felt the need fo butr larger wire and/or amps,the Ironman sound's like a good choice. If the Lincoln is repairable,it could stay loaded with small soilid wire and gas ready for thin materials while the Ironman does everything else. If the Lincoln turn's out to be unrepairable,you can switch wires on the Ironman or keep an eye out for a small machine to dedicate to thin material to save changing settings on the Iron M. If you aren't planning to weld more than 1/4",I'd try and get something used that could be resold if and when Lincoln is fixed. I have a Lincoln Pro-Mig 180 that I love but rarly need to weld more than !/4". When I weld thicker,I take time to bevel and make multiple passes. If I did it every day I'd step up to a larger machine.
I've seen more than one Ironman in professional shops so they are evidently a good machine.
I took my SP-175 to an electric shop yesterday morning. It's where the local welder sends his equipment for repair.
On their front door were several stickers and labels; two of them were for Miller Welder Parts and Service, the other Lincoln Electric. They did not bat an eyelash over repairing my SP, so I think I'm in good hands. And $10 says it's going to be something super-stupid simple like a thermistor or equivalent.
I also have a line on a small 125 vac MIG through my bricklayer. Hopefully he gets back to me today and it's still for sale.
/ Another welder advice thread #11
The local TSC has 230 on super sale for 999. If I was into that kind of thing would be temped to buy it for resale. The store is such a disaster they dont sell many welders.
/ Another welder advice thread #12
If you told me 30 years ago the price on these basic machines would be nearly the same as then I would have said no way If you said my go to would be a 50$ drill I would have said you have lost it. The 240 is less than I paid for a 255 in early 90's.
Some people have great luck with used, got a cousin just bought a 140 like new with all the fixins for 150. Bottle full and all. There are some 120v used, not so much for the rest of them as people get the small ones and want to trade up and when they do they keep them. A lot of 210 class sold,,, very few on the used market. The cost has dropped to entertainment level, hobby level that its not such a gut wrenching decision any more. When I bough most of mine a guy needed to work to pay for them. It was a business decision. Now they are so affordable they can be a want and in lots of places can recover their cost in a couple events, maybe even a single one in the case of stick inverters.
/ Another welder advice thread #13
I just got a Weldpro MIG200Dsv welder, $780 from amazon. Does MIG, stick, and lift TIG. Runs off 120 or 240v, up to 200 amps on 240. I've run a bit of 7018 stick and 0.030 flux core wire through it last weekend, both ran very smooth. I'm pretty impressed so far.
Well I took a gamble on an estate sale welder for fairly cheap price; Lincoln Pro Mig 140. No gas regulator and it was missing the spool reel for using the 8" reel. Got it running with .030 solid wire, then put the -175 regulator and gas bottle on it: no gas. Which means the gas solenoid is bad (about $85) or something on the control board is bad.
Anyone know how to troubleshoot the solenoid so I don't have to risk another $85?
If not, I'll just run it with .030/.035 flux core; it's not ideal, but it's better than no welder at all or until another gas Mig shows up and I flip this one.
Thanks,
/ Another welder advice thread #15
I babbled a bit on Hobart about the risk reward of this and vs new.
/ Another welder advice thread #16
Did you double check to make sure you got the gun seated all the way in the power block or pull the cover and check solenoid function? I just don't see solenoids failing very often.
/ Another welder advice thread #17
Have the older style, bigger Miller 211. Been a pleasure to use. Used over 150# of wire in ten years. Would buy again.
Before using added a longer, bigger and better grounding lead and clamp. Eventually added a Miller 15’ gun.
Yea, the gun is seated all the way. I found a number of things that needed work: ground clamp, the reel parts, I did a general tune-up. No solenoid function: can't hear it clicking.
/ Another welder advice thread #19
Thanks!
purchased a Amico stick welder been well pleased, my son say it welds good as some couple thousand dollar welders he uses at work. 80% work capacity $180 bucks and it's 110 v, I had a flux core couldn't make any type of fair weld but it was cheap also.
/ Another welder advice thread #20
I probably have a couple laying around if interested.
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2012 VANTAGE TRAILER PMEUMATIC CEMENT TRANSPORT TRAILER (A63569)
2012 VANTAGE...
2015 John Deere R4038 Sprayer (A63109)
2015 John Deere...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
