Sick of cheap box store riding mowers. 1500-3k budget used zero turns?
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #1
p0opstlnksal0t
Eliot, Maine
in the market
Looking at a couple high-end older used mowers. I'm on my second Craftsman t3000 which has been junk. Am I better off with one of these older far superior-made machines?
The g1800 is 2500 bucks, the t1870 is 1800 and the Honda is 1,100. I also found a simplicity zero turn for $1800 that looks like it's not too bad
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #2
Have you checked out the cub cadet? 54 inch deck
about $2000?
willy
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #3
View attachment 699117View attachment 699118View attachment 699119
I would run from the Honda...
still have that models big brother (4518h). it sits in pieces. hydro jerks back and forth, that's when it would run...
Ignition problems, charging problems, starting problems, PTO clutch problems
parts are $$$
I have had much better service from my Hydro MTD that has the Peerless/ Eaton hydrostat, still smooth as silk with 35 years of use.
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #5
Many, many years ago - I gave up on box store mowers. My "old" mower is a Kubota G100. I use it for the REALLY tough cutting. Wild rose bushes, buck brush and mowing the field grass in newly opened meadows. My new mower is a Kubota X570. I mow two acres of "grass". About one and a half acres is meadow. Keep it mowed and after a couple years it will look, almost, like a real lawn. All the lawn provides a fire break around the house and outbuildings. This is a meadow I just opened up last year. Sure looks smooth in this picture. Well, it's not. Like most of my lawn - 2 to 3 mph is max.
about $2000?
willy
I saw them in Lowe's or home Depot I can't remember honestly wasn't impressed didn't seem any better than the Craftsman or Husqvarna that was in there.
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #7
I would look for a used Simplicity Conquest if you can find one. I had one for 4 years and traded on a Ventrac
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #11
90's simplicity regent. Very beaten up, will need to be replaced eventually. I use it for aerating and cutting the rough grass areas.
Heres a few more that popped up on FB:
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #14
you posted pictures of lawn mowers not zero turn. those lawn tractors are no better than the box store junk. go with true zero turn
Ya I'm thinking I'll go zero turn. The Kubota g1800 it's just too old now and parts I think are going to cost a fortune when it breaks
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #16
If you have reasonable flat mowing landscape, a ZT would be good. Otherwise, they can be tricky/dangerous on slopes. Just got a Ryobi ZT 48v. Went flying down into my neighbor's tall grass off a compound slope with it. Bought it to help me with the lawn up around the house. Fine for that.
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #17
Those mowers are not "zero turn"?
You think the SCAG Cougar shown is "box store junk"?
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #18
Good friend bought a Bad boys mower, older and needed work. Sunk a few hours into it . He beats the tar out of it. He loves it.
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #19
You can get a new Toro Timecutter with the 14 hp engine for $2,600.
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #20
17601CFL (A59228)
17601CFL (A59228)
MASSEY FERGUSON DL250 FRONT LOADER (A59823)
MASSEY FERGUSON...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
Ford Pickup Truck Bed (A59230)
Ford Pickup Truck...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A59230)
2012 Mack CXU613...
