Backhoe NEW MT225S owner....mechanical thumb issue
   / NEW MT225S owner....mechanical thumb issue #21
OK... Went easy until I curled the bucket to align for the pin. I started hitting the thumb with the bucket gusset and when I went to back off I moved the control the wrong way and started shearing the bottom of the thumb (See #1).
Please take a look at this composite image. Is your thumb and bucket fabricated the same as mine? I am trying to decide if I want to modify the the thumb or the bucket. I don't think either will affect the strength but what do I know. Opinions?
I am leaning toward grinding on the thumb. (the Left side is almost done already anyway).
I paid $285 for the mech thumb here in Pennsylvania. I just did my 50 hour service (at 65...shhhh) and I am getting ready to install the thumb that sat in my shop all winter. I'm glad I checked here before starting. Thanks for the discovery, kormidoit.
(y)
   / NEW MT225S owner....mechanical thumb issue #23
I would grind the thumb... lots more pressure / stress on the bucket. My neighbor has the 225-S, the dealer ground the thumb when they ran into the same issue.
It was one of the first thumbs that came from LS, I believe they changed the manufacture of newer thumbs due to the same issue...
   / NEW MT225S owner....mechanical thumb issue #24
I wound up grinding on the thumb and a little bit off the bucket gusset. I can always weld something back in if the bucket appears to weaken. I also ground off the tabs on the adjustable brace so I can use the close pivot and store the thumb up against the dipper when it’s not in use.
   / NEW MT225S owner....mechanical thumb issue #25
Glad you got it to work out without too much trouble!
   / NEW MT225S owner....mechanical thumb issue #26
Well... I already broke it! lol
Holy crap. I move the main pin to the center of the thumb to get that triangle config for strength....seems to work.
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2008 Toyota Camry Sedan (A59231)
2008 Toyota Camry...
Case skid steer wheels and tires (A56438)
Case skid steer...
Spreader Attachment (A56859)
Spreader...
2013 Chevrolet Silverado 1500 Pickup Truck (A59230)
2013 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
