Land is cleared... now what?
/ Land is cleared... now what? #1
northcaroliney
Searching
We’ve got approximately 8 acres recently cleared and dialed. I suspect the best thing would be to run a cultipacker over it to help level and seed, but I don’t have one and can’t find one to rent. What’s my next best option? It’s still somewhat rough - some sticks, rocks, etc and some areas where a little leveling may help. Would you jus throw seed down now and deal with it in the fall (maybe run a soil pulverizer and then a roller over it?) or...? Intended for horse pasture, and now that I see how nice it can look, I love the idea of it being really well groomed. Not quite golf course but that’d be nice... 🤣
/ Land is cleared... now what? #3
You could make yourself a "drag". Mine is made out of 4x4's and has spikes on the leading and trailing edges. It could also be - old set of bed springs, a couple logs chained together, rail road ties - etc. Drag it to level and bust up the clods. Spread your seeds - drag a final time to cover the seeds. Mine has a rope harness and I pull it with my ATV. I drag with the spikes down to level and bust the clods. Turn it over to smooth.
/ Land is cleared... now what? #6
Not sure what if any tractor that you have but you could buy an old bog disk fairly cheap from Craigslist or FB Marketplace to work up your ground with. Then pull a drag as described in previous posts across it to smooth.
/ Land is cleared... now what? #7
Take a look at buying a Landscape rake (root rake) for a tractor. If you are planting grass, I would wait until fall.
/ Land is cleared... now what? #8
Where abouts do you live? I used my soil pulverizer only a couple of times (bought from a guy that did the same). Now I mainly use it as extra weight on my disks!!
Feel a root rake will just pull the dirt clumps with everything we actually need to collect. Land is mostly clay so the big clumps left by the disk are effectively brick basketballs.
/ Land is cleared... now what? #11
The traditional implement used to smooth after a Disc Harrow is a Chain Harrow.
However:
1) A Chain Harrow smooths but moves very little dirt.
2) A towed mat Chain Harrow is pretty cheap at Tractor Supply or other places and can be pulled behind an ATV or utility vehicle but Chain Harrows pick up a lot of trash and periodically removing trash is a major pain and tiring. Usually tail of mat is picked up manually and trash shaken out. Picking up trash and sticks may be a big benefit to you.
2a) A mat Chain Harrow can be modified to self clean using a TPH Boom Pole.
TSC CountyLine / Tarter BOOM POLE as CHAIN HARROW LIFT
3) A Chain Harrow is pretty good for covering large seeds. Small seeds, like grass, need light to germinate and are more likely to germinate when rolled in.
4) Every Chain Harrow I have used glides smoothly over stumps.
5) Do you know how to adjust Disc Harrow gang angles to reduce roughness behind the implement?
/ Land is cleared... now what? #12
If this is a one off deal, I'd pay a neighbor or small business to do it.
/ Land is cleared... now what? #13
Gotta do what you want with it. If you're looking for a nice lush pasture, I'd have it turned, find what grass does well in your area and when the correct planting time is for that particular seed, and plant and cultipack. Just depends on the crop you want. You could always have it turned over and plant a summer cover crop to boost soil health and get some organic matter going.
2016 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
360 Y-Drops (A65640)
New/Unused Landhonor Power Rake (A65583)
New/Unused...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
