Land is cleared... now what?
   / Land is cleared... now what? #1
northcaroliney
Searching
We’ve got approximately 8 acres recently cleared and dialed. I suspect the best thing would be to run a cultipacker over it to help level and seed, but I don’t have one and can’t find one to rent. What’s my next best option? It’s still somewhat rough - some sticks, rocks, etc and some areas where a little leveling may help. Would you jus throw seed down now and deal with it in the fall (maybe run a soil pulverizer and then a roller over it?) or...? Intended for horse pasture, and now that I see how nice it can look, I love the idea of it being really well groomed. Not quite golf course but that’d be nice... 🤣
   / Land is cleared... now what? #3
You could make yourself a "drag". Mine is made out of 4x4's and has spikes on the leading and trailing edges. It could also be - old set of bed springs, a couple logs chained together, rail road ties - etc. Drag it to level and bust up the clods. Spread your seeds - drag a final time to cover the seeds. Mine has a rope harness and I pull it with my ATV. I drag with the spikes down to level and bust the clods. Turn it over to smooth.
   / Land is cleared... now what? #6
Not sure what if any tractor that you have but you could buy an old bog disk fairly cheap from Craigslist or FB Marketplace to work up your ground with. Then pull a drag as described in previous posts across it to smooth.
   / Land is cleared... now what? #7
Take a look at buying a Landscape rake (root rake) for a tractor. If you are planting grass, I would wait until fall.
   / Land is cleared... now what? #8
Where abouts do you live? I used my soil pulverizer only a couple of times (bought from a guy that did the same). Now I mainly use it as extra weight on my disks!!
Feel a root rake will just pull the dirt clumps with everything we actually need to collect. Land is mostly clay so the big clumps left by the disk are effectively brick basketballs.
2008 Ford Ambulance (A47477)
2008 Ford...
2019 International DuraStar 4300 24FT Box Truck (A53422)
2019 International...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2019 Ford F-150...
John Deere 85G Quick Attach Brackets (A50775)
John Deere 85G...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
