Cell Phone & WeBoost
/ Cell Phone & WeBoost #21
My daughter in law had okay cell signal outside her house, inside not so much. She could only make calls when she was sitting by one upstairs bedroom window. I found out that her house has aluminum siding with a metal roof. I got her an external antenna/repeater setup, which is no longer made. Now she can make a call from anywhere in her house and she can use her cell hot spot for internet access. Made her and her husband happy campers.
/ Cell Phone & WeBoost #22
Our phone service was just great when we had the analog Motorola bag phone and roof top antennae. Then along comes digital cell phones. I have to stand out on the front porch to use my cell phone.
So..... the cell phone sits over there in the roll top desk - OFF. A couple times a week I will go out on the porch and see if I got any calls worth returning. Thank you modern technology .......
/ Cell Phone & WeBoost #23
Outdoor WiFi Extenders, Antennas and Repeaters by Simple WiFi — SimpleWiFi
It does seem the field is growing...
I use my phone as a hot spot effectively because when I place it high up on an exposed beam the signal is very good... a few feet lower and maybe one bar...
Did not know the carrier limited hot spot usage until I got a warning but it was two days before reset.
At Mom's even Verizon was only one bar... always no or little signal
Don't know what happened but Christmas day 3 bars... and never less than 2.
Maybe Santa was listening?
/ Cell Phone & WeBoost #24
Subscribed, need to get reception inside the shop, a metal building. Have good signal in the house.
My flip phone is 3G.
Update: I ordered this: Home MultiRoom Cell Phone Signal Booster | weBoost
Installed it in the shop with the outside antenna temporarily next to the window that I could get signal through inside with the flip phone close to it.
Works great, went from no signal in the center of the shop, to full signal. Now I get a stronger signal any where in the shop than in the house. (y)
/ Cell Phone & WeBoost #25
View attachment 698388View attachment 698389
I tried the above setup at my house. But I was not able to consistent boosted results. Glad it improves your signal. I also sit in a low area with hills around me. And lots of trees. We estimated our roof top antenna was higher than the top of the cell tower our signal came from. don't know if that effected the signal. My -dbm ranges from -120 to -114. Not great. Jon
/ Cell Phone & WeBoost #26
Very happy with the performance of the system.
Moved the panel antenna from it's temporary location up higher to it's permanent location on the truss:
Moved the booster from setting on a box on the bench up onto the pegboard:
/ Cell Phone & WeBoost #27
Glad it is working for you X-man. I wish I could have had decent results, but couldn't. Jon
/ Cell Phone & WeBoost #28
I am surprised that it is working with the outside antenna so low. The tower it is pointed at is over the high spot south of the horse barn, it is 8 miles away and 225 feet tall.
The red line shows the way the antenna is pointing:
/ Cell Phone & WeBoost #29
After Verizon bought Tracfone my flip phone (upgraded to 4G) signal in the shop was very weak. So I found out that the closest Verizon tower is on the other side of the shop. Didn't want to put the antenna up on the roof, so I pointed it at the side of the barn to see if a reflected signal would work:
Success, I now have 4 bar signal strength in the shop and the antenna is still low.
The antenna viewed from the barn where it is pointed:
/ Cell Phone & WeBoost #30
clever solution to get the reflected signal vs. the primary.
Metal is great for that.
iDrive TDS-2010H...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2017 CHEVROLET SUBURBAN(INOPERABLE) (A60736)
2017 CHEVROLET...
Kubota M1048A Forks (A60462)
Kubota M1048A...
