Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,313
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
It won't run at full-power.
It stumbles and dies periodically (often).
I am able to work it lightly at about 1/3 throttle, but whenever the control system pours the coal to it, it stumbles and often quits.
When not stumbling, the engine is perfectly smooth.
I'm not a diesel mechanic but I may be on the path to becoming one (just for this machine).
Fuel filter looks recent. Poured it out into a pan and no sediment appeared.
Air filter is recent (looks new too).
This problem is on-going for years, Kubota dealer unable to fix it.
Kubota dealer replaced the injectors at about 400 hours which did not eliminate the problem, which has become much more frequent.
I think possibly they have a harder time identifying the problem because the Kubota dealer can't dig with it.
2016 KX040-4, 1400 hrs, 9800 lbs
Not my machine. Owner is letting me borrow it to dig at my place in hopes I might find the problem and he knows I'm a persistent sob.
He needs to lend it to a genuine diesel mechanic, but that opportunity has not arisen.
But I'm happy to have it here even if I have to run it at 1/3 throttle.
There's an air bleeder valve at the top of the fuel filter block.
Opening it often ejects some air.
I put a clear hose onto it and eject into a fuel can, and eject air, until it's fully clear of air.
But later the problem returns and I check the ejector valve and there's air bubbles in the fuel stream.
It acts (to me) like there's a candy wrapper in the tank that periodically gets sucked onto the inlet. Then it stumbles, the machine lurches, and the wrapper washes away, clearing the inlet.
What I've done:
Clean water separator. It shows no air bubbles in the visible part. It has a new o-ring.
Removed and cleaned the fuel tank. Removed the fuel level sensor, so I could LOOK inside the tank. There was only a very tiny amount of sediment/water in the bottom. I made it so clean you could drink out of it. Tank is frickin' clean.
I blew out the line from the water separator to the tank with compressed air.
There is a vent line to the tank that has a one-way valve. I sucked on it and it flows one way (to the tank) cannot blow out to it.
On the fuel separator (which is under suction from the fuel lift pump) one of the nipples is 'ever so slightly' loose. I can wiggle it. It seems like it can let in air, but can't be much. This nipple fitting is like a glued-in/crimped in fitting, a permanent nipple on the separator.
One question I have, is, does a modern Kubota have an air ejection process capable to eject air? The air I'm ejecting from the fuel filter (manually) ..... can the system do this on it's own?
What I've done:
