May 8, 2021 / Cleaning zerks #1 J Jw5875 Gold Member Joined Aug 27, 2005 Messages 414 Location NW Pa. Tractor Kubota L3400 Found this on you tube and is a great way to clean out recessed areas around zerk fittings. A few squirts of WD40 afterwards makes the next greasing easier. JW5875
May 8, 2021 / Cleaning zerks #2 oosik Epic Contributor Joined Aug 22, 2012 Messages 20,887 Location AMBER, WA Tractor 2009 Kubota M6040 Handy
May 8, 2021 / Cleaning zerks #3 S Smokeydog Elite Member Joined Jan 20, 2019 Messages 3,213 Location Knoxville, Tennessee Tractor Kubota B26, M59, M5030DT Always used a stick. Now see a better way. Maybe cut some teeth on the tubing for the lower ones packed with mud? Good tip.
May 8, 2021 / Cleaning zerks #4 JCoastie Platinum Member Joined Aug 29, 2020 Messages 846 Location Coastal AL Tractor LS MT240HE I use q-tips, quick easy, double sided, cheap, disposable, no cutting, etc.
May 8, 2021 / Cleaning zerks #5 S SylvainG Platinum Member Joined Jan 30, 2021 Messages 643 Location South West, Qc Tractor Kioti LK30 I put cap on them, They are always clean
May 8, 2021 / Cleaning zerks #6 grsthegreat Super Star Member Joined Jan 26, 2011 Messages 14,817 Location north idaho Tractor Kioti DK45SE hst cab I just hit them with compressed air.
May 9, 2021 / Cleaning zerks #7 LS Tractor Owner Super Member Joined May 1, 2017 Messages 7,665 Location Edgewood, NM Tractor LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500 I also keep caps on ever one of the zerks.... pop it off, grease, put back on.... easy peasy
May 9, 2021 / Cleaning zerks #8 H hube2 Veteran Member Joined Sep 4, 2020 Messages 1,234 Location Paris, NY Tractor Masey Ferguson GC1725M Yep, caps keep them clean.
May 9, 2021 / Cleaning zerks #9 Cycledude Veteran Member Joined Nov 26, 2020 Messages 1,670 Location Rib Lake Wisconsin Tractor LS XR4155, Ford 6610, Ford 8n Caps made for grease zerks ? I was not aware they were even available
May 9, 2021 / Cleaning zerks #10 S SylvainG Platinum Member Joined Jan 30, 2021 Messages 643 Location South West, Qc Tractor Kioti LK30 That's what I bought: Boeray 800pcs M6 M8 M10 Polyethylene Plastic Oil Grease Gun Zerk Fitting Dust Cover Cap Cover Assortment Kits,Red Blue Green : Amazon.ca: Automotive Boeray 800pcs M6 M8 M10 Polyethylene Plastic Oil Grease Gun Zerk Fitting Dust Cover Cap Cover Assortment Kits,Red Blue Green : Amazon.ca: Automotive www.amazon.ca
May 10, 2021 / Cleaning zerks #11 ranger danger Silver Member Joined Nov 18, 2018 Messages 232 Location East of Hangtown Ca Tractor Kubota M6060, MEB802 Generator Cycledude said: Caps made for grease zerks ? I was not aware they were even available Click to expand... I always use vacuum caps. They work great and are cheap and easy to replace.
May 10, 2021 / Cleaning zerks #12 H hube2 Veteran Member Joined Sep 4, 2020 Messages 1,234 Location Paris, NY Tractor Masey Ferguson GC1725M I use these LockNLube Grease Fitting Caps (50 Count) (Yellow): Amazon.ca: Automotive
