Tractor backhoe - homemade
/ Tractor backhoe - homemade #1,462
When I see new posts here, I'm hoping it's a progress post but often disappointed by just posts like these. Oops, here I go too lol.
It's like hand writing, the more you do it the better it looks. It's also important to buy a good welder. Now I own a Synergy Mig welder with 380 Amps max current and water cooled torch, but next "wish" is a dual pulse welder. That's a long term plan...
/ Tractor backhoe - homemade #1,466
Your handwriting is looking good. :)
/ Tractor backhoe - homemade #1,467
At work we run a bunch of Fronius pulse welders. Once it wasnt new anymore, the pulse possibility is hardly ever used. And when its used, its for the root pass on 40mm thick steel. So the 8000 euro extra price really goes to waste in the work that you do.
Really, why? From what I saw they make a great weld. Which process is the best?
/ Tractor backhoe - homemade #1,469
Pulse welding gives better penetration in a sharp beveled seam because it allows you to put more heat into the same amount of welding wire, but the guys prefer a steady arc for finish welds, which gives smoother appearance. These Fronius do have a more stable arc when pulse welding isnt used though, but that has to do with the overall quality of the AC/DC converter and leveller in these 16.000 euro welders, not with their pulse weld ability...
So you think it's not worth extra money. I'm satisfied with my Synergy right now but figured the pulse is an improvement...
/ Tractor backhoe - homemade #1,471
Well the salesman told us too so we bought four of them. They weld great, but the pulse isnt used often (you can hear a sonic whine in the office when they use the pulse option) once everybody tried this new gadget, they now use it only to penetrate the root pass of a beveled V weld. For filling the other layers it isnt used because it has no merits then, but gives a slightly rougher finish. In hindsight we would probably not have paid for the pulse option...
Anyway, I turned and centered and welded main swing mechanism....now for the hardest and believe me the most complicated part of the machine...swing cylinders. Anyone who is familliar with this issue knows that this combined movement of those two swing cylinders does not forgive any mistakes. There is a 5 mm window in geometry in which this works...
/ Tractor backhoe - homemade #1,475
Renze just saved a lot of people a lot of money. All the wives are happy!!!
I said the pulse mig isnt worth the money unless youre doing root passes on one inch or thicker. Not that the expensive welders didnt give better, more stable arc than our older ones when filling large bevels without pulsing.
/ Tractor backhoe - homemade #1,476
Yup.. isnt it satisfying when you get it just right ? 😄💪
Ofcourse. There is a ton of planning and drawing behid the geometric solution. I've figured quite fast that at half point of the swing cylinders get in a impossible position where they should both go out to achieve this arc unless you manage to get that lever ratio under 5 mm.
/ Tractor backhoe - homemade #1,478
Its not uncommon for a swing setup to have one of the two cylinders at, or slightly over its dead point so it actually works against. But because it works against at its dead end, while the other works with full arm, its ok.
180 degree swing sets for a swivel loader are worst. For a backhoe where you can use trunnion mount its much better, and for articulated loaders its easy because they only have to do 80 to 90 degrees....
Testing the oil tank for leakage; passed ;)
So I welded top cover and painted it
After that I made kingpost braking cylinders, 4 of them, one in each corner.
Turning them on the lathe after welding. It was almost unnecessary
Sooo...after alot of other projects I decided to finally finish this one. Welding of the swing cylinders and preparing upper holding plate... This has to be welded dissasembled not to burn those seals in the cylinders...
TOTE OF HEAVYEQUIPMENT HOSES (A68842)
TOTE OF...
2012 KENWORTH TROAXLE BODY  LOAD (A67714)
2012 KENWORTH...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2018 Kubota...
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
2018 Kawasaki 4x4 Diesel Utility Cart (A66734)
2018 Kawasaki 4x4...
