stalling engin
/ stalling engin #1
Rockbadchild
Elite Member
northern Ontario Canada
2076E Massey Ferguson
hi everyone
let me just start by saying i am happy i found this site you guys are really useful and helpful thanks ....
i’ve got a question, with my 2015 massey ferguson 2606E hydrostatic (60hp) with 700 hours. i’ve bought it a months ago from a dealer has been fully check and services from the dealer ... while plowing with a two furrow plow ive stalled it once on the turtle speed setting, then i’ve changed it to the low gear (snail setting) and its better but i’ve stalled it a few other time while going through patch's of clay ... so while hitting resistance, the RPM decrease to a stalled if i don’t decrease my speed. is this normal ? like i’ve pulled trees out of the ground with it and it didn’t do that, it would spin the wheels, not stalled!! Perhaps because the plow just put so much traction it kill the engin ? i also had the front end loader on it if it makes a difference .... but the soil is wet and soft, it feels like if i am running out of fuel ... i am running dyed fuel but that’s shouldn’t matter ? there is no DPF ... after reading online i will check the seat sensor and the inner tube for the air filter and clean the air filter but any other suggestion ???
thanks
/ stalling engin #2
Are you running the RPMs on the engine on up there (at least 2000 rpm or better)?
Second thing, hydrostats are funky in that when you start to bog down you have to let up on the go pedal for more power - mashing it down further will stall it further. It is counterintuitive, especially if you are used to running a gear machine.
/ stalling engin #3
Second on the rpms...are you plowing at the PTO rated speed or better for maximum pressure to hydo? My Boomer will stall on steep grades if I mash the pedal, it's like shifting to higher gear. Let up on go pedal to keep rpms above 2000 if possible in the gear range you are using.
/ stalling engin
yes it did it at 2200 but it was better at 2500 rpm ...
ha yes now that you say it, it’s makes sense.
thanks
/ stalling engin #5
Also, not sure if your tractor has it or not, but if you have a draft control by your 3pt lever you might try experimenting with it so that it will raise your plows up a little before you stall out. It will drop them back down once you regain some traction.
/ stalling engin
yeah 10-4... i am not sure i will have to check that out.
/ stalling engin #7
My NX5510 has an "anti-stall" feature. I don't really use it much. I think that one can get a seat-of-the-pants feel and mange (slow down; shift-down; adjust load- less load or raise implement such as a plow). Nothing like the feel of churning ponies that all of a sudden start bucking on you (accompanied by a smattering of black smoke)!
2006 Peterbilt 387 Semi (A64047)
2006 Peterbilt 387...
2021 John Deere 1775NT Planter (A63109)
2021 John Deere...
Coats 5060AX Rim Clamp (A63118)
Coats 5060AX Rim...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
(INOP) 1988 MANITOU R522-4TC TELESCOPIC FORKLIFT (A62130)
(INOP) 1988...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
