What else do you do with forks besides lift pallets?
/ What else do you do with forks besides lift pallets? #421
Mine are handy but i've destroyed many a pallet etc and i harpoon the dirt all the time. i got many hours under my belt driving lift trucks, i can do it but.....a factory and it's outside yard have flat surfaces to ride around on, nothing close to flat here!
its on and off many times and then i still screw the pooch. yesterday i destroyed a crate with 25 pieces of 25 ft metal for the roof, left overs.
Neighbor stopped by with camera on his 4 x 4. i gotta get one!
/ What else do you do with forks besides lift pallets? #422
I sometimes use my forks to arrange my pallets as 'inverted Vs'... but I don't know why?
/ What else do you do with forks besides lift pallets? #423
^^^^^ Danger Will Robinson... Danger!
/ What else do you do with forks besides lift pallets? #425
I have a cabbed tractor so I bought 48" Forks. At least now I can see the fork tips. I need to get my camera system installed this winter for even better vision.
Sorry for late response.
My plan is 48" forks for Brush Piles around the property, thinking even a Debris Fork. Max28 Compact Tractor, lift limits were called out at 1600 lbs. but I'm thinking it will be working hard to get anywhere near that. I'm thinking of getting the 4000-lbs. forks, hopefully they will hold together with the lite work I'm planning.
Camera System sounds good, (installed yet ?), my tractor is small enough but a Backup Camera wouldn't hurt.
Novel idea here but I finally decided to use my forks to lift a pallet. The problem was loading a 3pt chipper onto a trailer. There were no hooks to pick it up and its was so awkward I could easily have dropped it. There was no good way to line forks under it.
Solution was to put the chipper on a pallet, strap it down and then pick the whole pallet/chipper bundle up with my forks. Problem solved and finally used forks as intended.
/ What else do you do with forks besides lift pallets? #429
Used mine today to put my 5th wheel hitch back in my truck for the season.
Sure beats doing it the hard way.
/ What else do you do with forks besides lift pallets? #430
Turn it around, chain it down and you can use your tractor for moving your trailer around.
We used to do that with full sized fifth wheel plates to move empty semi trailers around.
/ What else do you do with forks besides lift pallets? #431
Ah no, even empty the pin weight is too high to be able to lift it with the FEL. Let alone move it around over uneven ground.
/ What else do you do with forks besides lift pallets? #432
That brought back memories from 17 years ago:
/ What else do you do with forks besides lift pallets? #434
Xfaxman - You do not even list that Massey in your tractors.
/ What else do you do with forks besides lift pallets? #435
Found a new thing last weekend. I had an old cultipacker that had been here since I bought the place 25 years ago. It was already very rusty and would not roll then but I had nothing to lift it and just never got around to cutting it up to get it out of here. And of course over time a tree grew up through it and wrapped itself around some of the bars. Since I got my Versatile with the forks and it was soft last weekend I decided that it would be a good time to try and move that cultipacker which had of course sunk into the ground some over time. So under the cultipacker went the forks but lifting wasn't doing it with the tree roots anchoring it well. Slowly though I eased it forward with lifting pressure on and finally the tree roots gave way and the unit moved. not sure I could have done it without the forks because the bucket wasn't going under it.
/ What else do you do with forks besides lift pallets? #436
no curl action here, even the steering was slow to respond
/ What else do you do with forks besides lift pallets? #437
When I am brush hog mowing in the pasture, if I see it in time I like to stick the forks into an ant hill and mess it up..
Then kind of hover over the ant hill with the brush hog a bit.. It really messes up there day..
/ What else do you do with forks besides lift pallets? #438
I ordered a nice plastic pallet, the most common pallet size and 6000 pound capacity, to fit in my car. I also plan to use it as a work platform or scaffold, noting that unlike boards it can't slip sideways off the forks or tilt off because the tines pass inside it. I'll find a convenient spot to chain it to the fork frame so it can't slip off the ends, too, if I'm relying on it not to fall. (Yes, FELs aren't supposed to be counted on for safety, but I think a fall from 4 or 6 feet is a small enough risk.)
And the pallet arrived the other day.
When I order something big and heavy and rough, it arrives on a pallet. The most recent example would be the pallet forks themselves. But when I got this pallet, it arrived in a full sturdy cardboard box, with big "FRAGILE" stickers on it.
/ What else do you do with forks besides lift pallets? #439
Read my signature:
It is the tractor I sold 11 years ago when I got my first compact telehandler, the V518:
International S1900 (A61306)
International...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Toro Groundsmaster 4000D Batwing Commercial Rotary Mower (A59228)
2018 Toro...
2021 Forest River Puma PUT31QBBH Travel Trailer (A60352)
2021 Forest River...
