Need Tractor/Truck Recommendation
/ Need Tractor/Truck Recommendation #21
If you can do the routine maintenance on cars and trucks a tractor isn't much harder. Mostly I needed larger tools and oil containers.
If you do the routine maintenance, you don't need a dealer close by. Mine's 3 hours away one way. I've been there twice in four years. Once to test drive tractors and once to pick up a used backhoe. I rented a flatbed trailer for that. The dealer ships parts (I have primarily needed filters).
With 40 acres of forest I think there's a good chance you'll be wanting to move trees in some way or another. Carrying rounds out of the woods is really hard work. There's a lot of different implements from log hitches to log arches to grapples or forestry winches. And of course there's also chains and cables. But if your trees have any size to them they get heavy and you'll need a good sized tractor to handle them. The sub compacts your dealers are showing you aren't going to be able to do much.
The emissions regs for tractors between 26 and 75hp are easier to meet than that for pickup trucks. The equipment adds less to the purchase price. There's no DEF and usually no EGR, which are the two things that have caused the most problems with diesel trucks. With the exception of a few models like the old Kubota B3350 tractor emissions systems have been reliable. And the air you and your family breaths is cleaner. I dislike the stench of unfiltered diesel exhaust and I'm happy to pay a little extra to not have to breathe it.
/ Need Tractor/Truck Recommendation #22
Lots of good advice and opinions.
I would also think keeping the ZT, ditching the current truck (at least the plow), and looking at a 40hp cabbed machine in the 4000-5000 lb range. A 1/4 mile gravel drive in Vermont sounds like a lot of work to me, and you should consider your comfort while on the tractor IMHO.
I really like my Kubota L4060 cab tractor that I use primarily for much lighter snow plowing here in Maryland. Weighted rears and implements I come in at around 7000 lbs, which is important for snow plowing. The cab may be a liability if operating in tight wooded areas though.
Happy shopping!!!
/ Need Tractor/Truck Recommendation #23
The difference in cost between a non-EPA engine and the next step up to an EPA engine is roughly $3400.
Not all of that cost can be attributed to the EPA nonsense. Some of it is for the bigger engine
The difference between the 33HP Kubota and the 39 HP Kubota is about $2100.
So by extrapolation and using SWAG's I figure the cost of the EPA garbage to be about $1300. And that's the low end, IMO. Neither of the bigger Kubota's are turbocharged.
I'll take a check from anybody that wants to pay me for the EPA nonsense. Make it out to "Username's Fishing And Retirement Fund"
/ Need Tractor/Truck Recommendation #24
Definitely go up at least a couple steps in the tractor size.
Getting a BX for what you need to do is a recipe in frustration and self recrimination... beg, borrow or steal what you need to get the right tractor the first time!
Would you consider used (idk how far this is from you) or are you relying on financing?
Check on what it takes to attach a plow to a light duty truck - around here I only see full-size trucks with plows, and I know it's a lot of extra weight on the front so I'm not sure about plowing with a tacoma or something light like that (guessing you need a lot of weight in the bed at the very least, and probably beef up the front end? what's the long-term viability of doing this?)
Ok so yesterday I went to 1 Kubota and 1 JD dealer. Today I went to a different Kubota dealer. My ideas of what I want were more refined today. Learning that I could get some kind of trench bucket or spade attachment in place of a backhoe was revolutionary. So today's Kubota dealer and I talked it all out and landed on an LX2610 which is around the same price as the B2601. When I looked at the BX23S I just knew it was so small I would be really likely to tip it over. I'm going to get the loader, box blade, and (from a 3rd party) some kind of trench bucket with grapple.
/ Need Tractor/Truck Recommendation #26
I looked at the specs, it looks similar to the JD2025r I own, and maybe the Kubota has a little better loader. It looks like a nice tractor for your use, I wouldn‘t go any smaller.
/ Need Tractor/Truck Recommendation #27
I have a Kioti DK5010. Has been an xlnt tractor. The DK's are the more basic models which is reflected in the pricing. It is 50 hp which may be more than you need. The CK line gives more choice at less HP. There are other series as well. Might be worth checking out the Kioti dealer. If interested and negotiating price make sure they will deliver without extra cost. Also good to get with Rimguard filled rear tires to provide extra weight.
/ Need Tractor/Truck Recommendation #28
One more thing regarding Kioti. They are having their spring sale. Check under Financing section on their website. We took advantage of a great savings when we bought ours. One thing to note is that at one of the dealers we checked with did not even know about the sale package we were looking at so we went elsewhere.
/ Need Tractor/Truck Recommendation #29
Excellent choice. You're gonna love it. It has a lot of features the competition doesn't. Like a 3 range Hydro. (it matters)
Excellent choice.
There's a guy in Canada (I think) that has a nice youtube series and he just bought the LX2610 to replace the B2601. He Loves it. Tractor time with Tim just bought the LX3310 and he's a dedicated Deere-Dude. He loves it.
If I can find one at a reasonable price, that's what I'm zeroed in on and I've been shopping for 2 years. They're going up in price, however. Hope you did well.
/ Need Tractor/Truck Recommendation #30
Check out GP Outdoors on You Tube.Only thing I would add for Vermont is wheel spacers.
/ Need Tractor/Truck Recommendation #31
I have respect for Kioti. Problem is, some of their Dealers are, quite frankly, amateur hour. But that's to be expected when you're dealing with a company that's trying to get a footing in a big market.
/ Need Tractor/Truck Recommendation #32
Censalata-
With 75 acres, tractor ownership should be a condition of residency in VT. Lots of good feedback on TBN for any question related to rural survival. Before parting with too much $$ at a dealership, talk with friends, neighbors, fiends of friends who have experience with tractors. Personally, I don't buy anything new. If you do, be prepared to learn that a phD in computers will be as necessary for your tractor as for your Lexus. Fortunately I am able to do a lot of my own repairs on all my pre-1990s equipment. An FEL is indispensable, but not necessary on every machine.
/ Need Tractor/Truck Recommendation #33
OP, you need to PRIORITIZE. In one of your posts your mention that you want a backhoe for "convenience." That's not realistic thinking when you're specifying a ton of other things and with only $30k for all. Figure that that backhoe convenience is likely going to cost you a cab (and then some; I have zero regrets from going for a cab and not shelling out for a backhoe [I rent excavators; they can do what no backhoe can do; I PLAN my projects, something that ought to be standard practice by anyone who is serious about getting real work done]).
With equipment comes maintenance (and repairs- I once had to shell out $700 for a loader cylinder for my lowly B7800). It all adds up. Larger equipment will cost more to maintain, but it might also cost less in repairs in comparison to an undersized machine breaking from being over-strained.
You're going to have to settle on getting less OR getting stuff that's used. If you go through a dealer for used stuff you can get them to get everything up to proper working condition and still come in far cheaper than a new piece of equipment (which you will end up eating the initial depreciation on).
Unless you get a big enough tractor you're going to find that implements won't work as you might like. Consider the grade on your drive (you say some part of it is steep- how steep?), it might be that with an HST tractor you're going to find it a bit of a struggle to work in snow and go up-hill.
/ Need Tractor/Truck Recommendation #35
Smaller machine running a snow blower is going to be needing all the power it can get. HST tractors consume more power in their drivetrains. Plenty written about this.
I'm NOT bashing HSTs: I've got two tractors and a UTV with HST. Unless the OP is willing to go used and get a larger tractor she's going to have to make tough choices (on new).
/ Need Tractor/Truck Recommendation #36
Only things that I would add in all of the discussions are
Is a cab feasible in your woods. Cabs and woods are often not friendly with the cab and glass losing. I totally understand wanting the cab for the winters and snow removal, but a removal can may be a better fit for you. Do some research on that to reach a well informed decision.
I love my BB, but one of your wants was pulling stone from edge of drive back up on your drive. The BB will leave you frustrated on this task. You also need either a tradition rear blade or a landscape/root/york rake. Personally I have not used a rake, but many swear by them.
Depending on brand, many smaller compact tractors use a turbo to up the HP on smaller motors. Do your research on this as well. For EPA, it makes no difference how the HP increase was obtained, they still require the emission add-ons. Do your research on this as well as different brands deal with it differently.
While lots have focused on HP of the tractor, and I am not disagreeing that more HP is always nice, however, do not allow anyone to sell you a machine that will not physically fit where you want to take the tractor. Many suggest a larger HP tractor will do the job in less time. This is true, but only if you can get the tractor if you can get the tractor to the job. Often larger HP tractors are on larger frames (there is more weight and torque involved typically). Then you add a typically larger loader (granted more capable loader) and you may not find yourself with a tractor much longer, which takes space to maneuver. This space may not be available in your woods (at least without taking down trees)
Consider a grapple of some type. I suggest a flat bottom style. This just may be my preference on style, but I have used 2 styles and like the longer flat bottom for brush and longs.
Consider rear remotes. They can be added later, but you have to figure out the source for hydraulic fluid and return as well as the routing of the hoses. A T-N-T would be extremely helpful on a 1/4 mile long drive using a BB. TNT allows adjustments for road crowning and more or less aggressive cutting edge usage.
/ Need Tractor/Truck Recommendation #37
I think your current plan to keep the zero turn and ditch the old plow truck will work well. The Tacoma will be fine for your plowing needs and is great at holding it’s value. You won’t need to worry about a cab on the tractor if it’s not being used every day in the winter. Get a load of sand to spread if the driveway gets icy, but that’s about all you’ll use it for in the winter. Summer time will bring all kids of chores where the tractor will be helpful. Skip the big implements that cost a lot unless you plan to use them often. Enjoy and have fun.
/ Need Tractor/Truck Recommendation #38
I've got woods, and while it HAS resulted in busting out some glass (replaced a door), I wouldn't opt to NOT have a cab. I've got blackberry vines whipping all over the place. There's also heat to contend with (I have AC and it's nice). I can operate longer as it starts raining. I can have a video camera: that and everything else in the operator station is under cover. AND, not having to worry about swarms of bugs... NOTE: it took me over 550 hrs before damaging my cab/glass- $600 comes out to about $1/hr for all the protection that I've noted; this mistake was due to operator error, having the door open when I shouldn't have had it open*🙄 (I've done more damage to the loader from using my grapple [busted a tilt cylinder]- does that mean I shouldn't be working with a grapple in the woods?)
* If you're on and off the tractor a lot then a cab is going to be a hassle: that's why I'd left my door open- I was in and out a lot and it was really hot that day; running AC was meaningless as I'd have been cooling the great outdoors. I'm fortunate in that if I have lighter-duty stuff to do that requires a lot of hopping on and off the tractor I just run my B7800.
/ Need Tractor/Truck Recommendation #39
... My ideas of what I want were more refined today. ...
So glad to know that you are careful to consider some really good advice here. I have some notes to add. I've had my ranch for 24 years and have owned 7 tractors of varying sizes - 25 to 130 hp. Have plenty of woods.
A cab to deal with summer heat (where I am) or cold of winter makes a lot of sense if that is when you will be using your tractor. If you intend to do snow handling with a pickup, then maybe you won't have as much cold weather use. Or is that just short term?
You mention a lot of wants for tractor tasks. You don't need all of the attachments now, but you don't want to change tractors in the future to add something you think you need, so make sure your tractor 'can do it'. Assuming you want to use a snowplow/blower, normally with HP comes weight, which snow conditions need, so I would shy away from a tractor that is less than 3,000 lbs, and ensure it comes with a mid-PTO. Weight and size is also good for handling trees and tree parts. Also, for snow, watch the tires. R1 is much better than R4 or even R14, for snow or dirt or especially mud. You are not running up and down hard roads or doing a lot of loader work on concrete, so wear is a non-issue that may make some question R1.
Get the tractor with an OEM loader. Indispensable.
I bought a used a 25hp tractor with box blade (BB). Only used the BB 2-3 times because I found it not useful. It only pulls perpendicular because it cannot angle, and without adding hydraulics or manually cranking a 3 point arm, even tipping to drop the left or right edge is not going to happen. BB is not recommended unless you have an unspoken need. It will not help you with your road.
If you need help with holes for plants/trees, consider a post hole digger. It is essential if doing real post holes and can be used to dig a shallow hole for plants, then you can manually trim the edges away with a shovel until you get the diameter you want. If this is a common activity then do consider a front loader spade as you have mentioned.
A backhoe will be of limited use because if you intend to use the 3 point arms on the tractor, you must change everything out (most models). That is very time consuming and a PITA.
I bought my last 6 tractors as used on Tractorhouse.com. Tractors are not like cars - they are built to endure decades of use and do not become obsolete. If you target a low usage tractor, say 1000 hrs or less, you can get a lot of tractor for each dollar with low wear and high reliability. There are even dealers that can finance a used model. As for brands, some people say JD and Kubota are high dollar, but I say that through experience, customers have found out what will last, has reliability, unlikely to break or fail, has parts and service, and what has better resale value. They are willing to pay for those benefits.
/ Need Tractor/Truck Recommendation #40
MOST POPULAR TRACTOR BRANDS ARE RELIABLE, DEERE, KABOTA,KIOTI, MASSY FERGUSON, TYM ETC. SIT ON THEM AND TRY DRIVING THEM AROUND AND SEE WHICH FITS YOUR STATURE AND EYE, AND ARE COMFORTABLE. THE PRICS DIFFERENCES MIGHT SURPRISE YOU. UNITS WITH THE MOST MARKET SHARE WILL USUALLY BE MORE EXPENSIVE. LOOK AT " ASKTRACTORMIKE.COM" HE HAS SEVERAL VIDEOS ON BUYING YOUR FIRST TRACTOR. WELCOME TO THE FORUM AND GOOD LUCK.
FORD 5610 TRACTOR (A64276)
FORD 5610 TRACTOR...
Frontier RC2060 (A64126)
Frontier RC2060...
iDrive TDS-2010H...
(2) 26X12.00-12 TIRES W/ 5 LUG RIMS (A64280)
(2) 26X12.00-12...
2015 New Holland 560 Round Baler  5x6 Bales (A63688)
2015 New Holland...
30" X 11' ADS DRAINAGE PIPE (A64281)
30" X 11' ADS...
