Big Barn’s Retirement Farm Shop
   / Big Barn’s Retirement Farm Shop #4,571
Mine is rechargeable with permanent batterys. I need to keep it facing a light while being stored or there isn't enough of a charge to operated the auto dimming.
   / Big Barn’s Retirement Farm Shop #4,573
My Miller helmet has a "low battery" warning light when I first turn it on. I've only had to replace the battery once in since I bought it 15 years ago, mostly because of lack of use. Mine takes a AAA battery. I keep it on the gas cylinder. I make it a habit to only hang my helmet there after I turn the gas off. It's my way of making sure I don't lose a full tank because I forgot the valve.
Good practice for remembering to turn gas off.
My lids have low battery indicators but they either don't work or I failed to notice them.
Surprisingly two helmets actually use the SAME SIZE coin battery. (C2450). Things like that rarely happen to me.
   / Big Barn’s Retirement Farm Shop #4,575
Good idea as I have inadvertently emptied a few bottles. My reminder is that I always clean up my torch and hoses. When I do that the tap gets shut off.
   / Big Barn’s Retirement Farm Shop #4,576
Spalted always gets attention.
I would love that lathe. I only have an older Delta where I have to move belts to change speed. I've been tempted to change it over to a variable speed system.
Variable speed is sweet! I was so impressed I got the Nova drill press as well and sold off my belt driven tools.
   / Big Barn’s Retirement Farm Shop #4,577
I realize the above response was about a lathe, but.
We have an old (OK, not REAL OLD, about 40 years) Delta or maybe Rockwell drill press. There are three sets of sheaves, with RPM capability of something like 200-5,000 (may be a bit of exaggeration there, just going off memory from maybe 10 years ago which is the last time I really looked at it). It's VERY simple and quick to change - an L-shaped handle holds the motor in place, just loosen that and you can change one or both belts in 10-20 seconds. Unless I were an 8-hr x5-day drill press operator, doing jobs for 5 minutes at a time and everyone required a different speed, I can't possibly see the payoff of a VFD over a simple mechanical setup.
   / Big Barn’s Retirement Farm Shop #4,578
I do similar...and check that the gas is off like 15 times while cleaning up...:D
   / Big Barn’s Retirement Farm Shop #4,579
I guess it was time. Today I got flashed using my auto dark welding helmet and realized it needed batteries. And the reason I was using this helmet was because I was too lazy to replace batteries in my other lids.
So today I took the time to replace batteries, inner and outer lenses where necessary and generally clean my helmets.
DONE! I really don't do a lot of welding so I should be good for another 5 or 6 years.
Which helmet you prefer? Our old Millers (14 years old) gave up. So did my helmet I bought.
I ordered a cheap, smaller window Miller online for only $86. Waiting for it to come in. Had good reviews.
I really like my $100 (+ or-) Weldcote.
Lightweight and by far the most comfortable I have ever used.
Large viewing area and good clarity.
30pc. 16ft.x 3ft. Brown Metal Roof/ Wall Panels (A53424)
30pc. 16ft.x 3ft...
2018 Wacker Neuson RTSC3 Trench Compactor (A54865)
2018 Wacker Neuson...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2003 Pierce Spartan Pumper Fire Truck (A51692)
2003 Pierce...
Takeuchi TL150 Skid Steer (A54865)
Takeuchi TL150...
