How can you paint hardware cloth without a bunch of waste?
/ How can you paint hardware cloth without a bunch of waste? #12
How many square feet of hardware cloth are you thinking of painting?
/ How can you paint hardware cloth without a bunch of waste? #13
Brush or roller should work. You'll need paint that will adhere to galvanized metal and brush or roll both sides.
Any first coat should be primed with latex paint or primer. See why below. Problem with oils or alkyds is saponification, causing zinc to corrode profusely and oil paint to peel. (no use oil or std primers)
Pay attention to the subject of painting galvanized steel...
/ How can you paint hardware cloth without a bunch of waste? #14
No waste at all, if you are careful.
Bruce
/ How can you paint hardware cloth without a bunch of waste? #15
You can spray paint wire mesh from an angle...
Aim the spray can from a 30 to 45 degree angle to the face of the mesh, rather than from straight on, and work around the perimeter of each piece, keep the can moving with light spray paint applied.
As you work around each piece, it covers the edges of the individual wires, provides good paint coverage, and less wasted paint.
And is a 2 minute task.
/ How can you paint hardware cloth without a bunch of waste? #16
Does the descriptive term "hardware cloth" not exist in Canada?
Eh ???
If you ask for a rye and soda here you get "soda water and Canadian Club whiskey". It will cost you 4x more than south of the border and there is no happy hour, Eh!
/ How can you paint hardware cloth without a bunch of waste? #17
Depressing!
/ How can you paint hardware cloth without a bunch of waste? #18
But your beer is better.
/ How can you paint hardware cloth without a bunch of waste? #20
I just painted 12 square ft of galvanized steel and 6sq ft of PVC using a specific primer for alum and galvanized. (Rust-Oleum). It took one 12 oz can of their 2x spray to just top-coat the surfaces thinly. Can't guess what the coverage would be on mesh or HW cloth.
2021 JOHN DEERE 204L WHEEL LOADER (A62129)
2021 JOHN DEERE...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2019 FORD F-250 (INOPERABLE) (A60736)
2019 FORD F-250...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A61307)
2023 Kubota...
Flatbed Truck (A55973)
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
