How can you paint hardware cloth without a bunch of waste?
   / How can you paint hardware cloth without a bunch of waste? #12
How many square feet of hardware cloth are you thinking of painting?
   / How can you paint hardware cloth without a bunch of waste? #13
Brush or roller should work. You'll need paint that will adhere to galvanized metal and brush or roll both sides.
Any first coat should be primed with latex paint or primer. See why below. Problem with oils or alkyds is saponification, causing zinc to corrode profusely and oil paint to peel. (no use oil or std primers)
Pay attention to the subject of painting galvanized steel...
   / How can you paint hardware cloth without a bunch of waste? #14
No waste at all, if you are careful.
Bruce
   / How can you paint hardware cloth without a bunch of waste? #15
You can spray paint wire mesh from an angle...
Aim the spray can from a 30 to 45 degree angle to the face of the mesh, rather than from straight on, and work around the perimeter of each piece, keep the can moving with light spray paint applied.
As you work around each piece, it covers the edges of the individual wires, provides good paint coverage, and less wasted paint.
And is a 2 minute task.
   / How can you paint hardware cloth without a bunch of waste? #16
Does the descriptive term "hardware cloth" not exist in Canada?
Eh ???
If you ask for a rye and soda here you get "soda water and Canadian Club whiskey". It will cost you 4x more than south of the border and there is no happy hour, Eh!
   / How can you paint hardware cloth without a bunch of waste? #17
Depressing!
   / How can you paint hardware cloth without a bunch of waste? #18
But your beer is better.
   / How can you paint hardware cloth without a bunch of waste? #19
I'll ask again...
   / How can you paint hardware cloth without a bunch of waste? #20
I just painted 12 square ft of galvanized steel and 6sq ft of PVC using a specific primer for alum and galvanized. (Rust-Oleum). It took one 12 oz can of their 2x spray to just top-coat the surfaces thinly. Can't guess what the coverage would be on mesh or HW cloth.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2019 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
