Ford 3400 Power Steering Issue
/ Ford 3400 Power Steering Issue #1
F3400
Ford 3400 JD1020
Hi, I picked up a 1963 Ford 3400. It had a couple of minor leaks in the steering column but functioned as it should. I decided to check the PS fluid level and top it off as needed. The manual said to pull the cap on the pump which I did. It had an O ring and a 3” spring under the plug. Replaced it and now my PS is dead. After doing some research I found that the 1963 had a reservoir for the PS up top by the radiator. So it looks like I pulled the wrong plug and now no PS. Thoughts, Suggestions, Hobby Mechanic in CT/MA?
/ Ford 3400 Power Steering Issue #2
Probably has an air lock. What did you do when you found the reservoir? 😏
Try starting the engine and moving the steering wheel back and forth through full turns.
The reservoir was just a little low. I brought it up to the level on the measuring stick that hangs from the reservoir cap. I have tried to slowly turn then wheels back and forth with ground pressure and with the bucket taking pressure off the front wheels. No luck as of yet.
/ Ford 3400 Power Steering Issue #4
Rotary valves (steering) need constant movement to pass fluid. Move the wheel like you mean it.
A picture of the part you disassembled might help. It may need a different procedure--Like cracking a hydraulic line(s). There's air trapped somewhere.
Thank you for your help with this. Here are a couple pictures from the shop manual
#13 is the plug I originally pulled
I pulled the pressure relief valve today. Worked the steering back a forth. Replaced and no luck.
