Ford 3400 Power Steering Issue
   / Ford 3400 Power Steering Issue #1
F3400
Ford 3400 JD1020
Hi, I picked up a 1963 Ford 3400. It had a couple of minor leaks in the steering column but functioned as it should. I decided to check the PS fluid level and top it off as needed. The manual said to pull the cap on the pump which I did. It had an O ring and a 3” spring under the plug. Replaced it and now my PS is dead. After doing some research I found that the 1963 had a reservoir for the PS up top by the radiator. So it looks like I pulled the wrong plug and now no PS. Thoughts, Suggestions, Hobby Mechanic in CT/MA?
   / Ford 3400 Power Steering Issue #2
Probably has an air lock. What did you do when you found the reservoir? 😏
Try starting the engine and moving the steering wheel back and forth through full turns.
The reservoir was just a little low. I brought it up to the level on the measuring stick that hangs from the reservoir cap. I have tried to slowly turn then wheels back and forth with ground pressure and with the bucket taking pressure off the front wheels. No luck as of yet.
   / Ford 3400 Power Steering Issue #4
Rotary valves (steering) need constant movement to pass fluid. Move the wheel like you mean it.
A picture of the part you disassembled might help. It may need a different procedure--Like cracking a hydraulic line(s). There's air trapped somewhere.
Thank you for your help with this. Here are a couple pictures from the shop manual
#13 is the plug I originally pulled
I pulled the pressure relief valve today. Worked the steering back a forth. Replaced and no luck.
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A51039)
Kuhns AE10 Small...
2020 CATERPILLAR Tl1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
GENERATOR HOUSE POEWERED BY TWIN 550HP (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2014 AMERITRAIL, INC. TUGGER TRAILER (A50854)
2014 AMERITRAIL...
2001 DITCH WITCH 8020 RIDE ON TRENCHER (A51242)
2001 DITCH WITCH...
