Want to buy a dump trailer, kinda torn here.
/ Want to buy a dump trailer, kinda torn here. #161
I have a 12 ft 12k trailer and when I was shopping for one I had to consider empty weight of the trailer and the weight of the load you can put in when you go to a 14k trailer the empty weight goes up so it's not like you can actually put another 2000lbs in it
Depends on the brand. There is very minimal weight difference between 6k and 7k axles. Usually there are other factors. Like longer trailer. Most 12k dumps are 12' long. Most 14k dumps are 14' long. And sometimes you get more under floor supports, or heavier gauge floor. So the upgrade to a 14k isnt always just about payload....but about how stout the trailer is and what size.
I have a 7x12 suretrac 12k. It weighs 3240# empty. An upgrade to 14k also means 14' long. The majority of the weight is simply the added length. But that said....it only adds 360# of curb weight. So while you dont get a whole 2k more payload.......you get pretty close and a bigger trailer to boot.
IF comparing two identical trailers.....and the ONLY difference were a pair of 6k vs a pair of 7k axles.....I doubt the difference would even be 100#
But as with all trailers, curb weight/payload vs overall construction is a trade-off. Build a light trailer on 8k axles and you will have alot of payload.....but will it hold up? OR build a tank on a pair of 6k axles and not even be able to haul 3-ton. Its a balancing act....and I think most of the big players have it figured out. Which puts a 7x14 bumper pull right around 4k empty with a 5 ton payload capacity
/ Want to buy a dump trailer, kinda torn here. #162
Almost all newer trucks now have factory 5th wheel/ GN prep with added cameras in the third brake light to see the GN ball. I back up to my GN alone in one attempt every time using the factory camera.
I have a 14" bumper pull, my next will be a GN triple 7 dump, but I don't expect to need to mess with the CDL crap or combined registration. I'm in an area that doesn't mess with you, and I don't see me needing to leave my area. I think a lot of the determination depends on where you live and how the police do or don't look for that stuff.
Yep, the law pretty much leaves privateers alone here as long as nothing looks ridiculous.
/ Want to buy a dump trailer, kinda torn here. #163
Same in my area of central ohio. I worry the day it changes. I cannot even tow a 14k trailer with my dually without going over 26k. But anyone and everyone with the exact same truck minus two wheels are perfectly "legal". Never mind if I want to tow my dual tandem GN 25' trailer. Just blows my mind how "legally" you are to be held to the same standard as OTR tractor/trailer drivers in a big semi and 53' trailer.
/ Want to buy a dump trailer, kinda torn here. #164
I guess I’ll have to get a CDL someday but around here you can tow whatever you want and drive whatever you want. There’s probably more drivers in tandem dump trucks that don’t have proper license and tags than do.
/ Want to buy a dump trailer, kinda torn here. #165
#2....really uncommon. Hitch adds extra cost....and is a PITA if you arent already a camper person. Hogs up bed space. Cannot just unhook and have an empty bed. Gotta pull the heavy hitch out....and still have the rails. I have had two extended cab dodge trucks....both I could see the GN ball from the drivers seat. Simple to hook up. And if not....a $50 Chinese backup cam is less hassle and cheaper than dealing with a 5th wheel hitch. Just my 2 cents
I had a 5th wheel in the '90s; the hitch came out of the bed of the truck by removing a few pins, leaving two rails in the bed that stuck up just over half an inch. It's not gooseneck hide-a-hitch but it's close.
Still I don't think it's necessary, just clarifying...
Did you see the 8kaxles/big brakes/17.5 wheels & tires and 6”hoist on that trailer? And a 7ga floor, too.
I don’t think a 14k is in the same league, but if you don’t need that heavy built of a trailer, I understand
I was under the impression you wanted a 16’, 16k and would love to break your bank account, so I figured WTH, right? Its built like a tank, though, so yeah>more $
Was more so leaning towards a 16k trailer just because. In regards to the length I think the 14 foot might be the happy medium.
/ Want to buy a dump trailer, kinda torn here. #167
I have a 16k mostly because the price was right. I didn’t need the payload but I do like the 17.5 tires vs the 16s on a 14k.
/ Want to buy a dump trailer, kinda torn here. #168
After you do enough decades of hauling with trailers, you realize there’s so many different theories and strategies. Enough to make you crazy.
If you tend to be subject to overloading-carrying more random weight cargo, like wet/dry hay or wet/dry dirt, I would suggest a heavier built trailer. That way if you overload it here & there, it won’t break. Opting for 17.5k wheels/tires and 8k axles instead of 7k axles and 16” wheels/tires makes sense on a 16k trailer. Even though 7ks are enough (2k tongue weight) the heavier axles & wheel/tires give you a “margin of error” that the 7ks and the 16” wheel/tire doesn’t have as much of.
If you are carrying the same load almost every time, like a 11,000lb tractor for example, then you are fine with a 16k trailer with 7k axles and basic tires & wheels. But if you are hauling all sorts of different random loads, opt for the heavier running gear.
Even though the 16k trailer with 7k‘s and 16” wheel/tire actually has a few hundred more lbs payload than the 16k trailer with 8ks and 17.5” wheel/tire, the latter will hold up better to an overloading situation and hold up better in severe use in fields, rougher use and the running gear should hold up longer.
/ Want to buy a dump trailer, kinda torn here. #169
Scratch those tasks, I don’t leave PA, was correct before.
That is pretty wild. Per your link it is obviously a PA intrastate thing. I am not aware of any other state in the nation that has that number as a threshold.
Guess I'll throw my .02 cents worth in here.
#1 IIRC, a CDL is required if the GCWR is 26001 and over. I had a 2004 Dodge 3500 quad cab dually that had a GVW of 13500# and a 25' gooseneck flatbed with a GVW of 14000#. Even though I was not commercial, I would still had to have a CDL since my "total" GCVW was 27500#.
#2 If you go with a GN, consider having a fifth wheel pin installed on the trailer and using a 5th wheel RV style hitch. It is a lot easier to back into a 5th wheel than trying to line up to a ball in the bed that you can't see. Keep in mind that a large number of the 5th wheel style RV trailers have GVW's that are or exceed 18000#, so the hitch capacity won't be an issue.
Seems the fifth wheel would complicate things, I have no desire to own a fifth wheel camper to be honest so the versatility isn’t there for me. Plus they’re using a 24k plus bulldog coupler on the gooseneck so I think it will have more than enough rating.
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
