fel loader oversize results
/ fel loader oversize results #1
hdhawg7
790 john deere
Well to those people who helped answer my question about size loader on a jd 790. Mr. dumb a-- used loader for first time loaded bucket attempted to back out lost rear traction and you guessed it destroyed both sides final drive on front axle. I blame myself i know better. Now i have to figure out how to repair my mistakes. Lesson learned the hard way.
/ fel loader oversize results #2
I promise it will be expensive, very expensive. I move double 5x5 rounds with my M9 in the field all the time (with another on the back spear bit i's never in FWA. Unless you have above average mechanical skills and the specialized tools to take it apart and put it back together, Think I'd leave that to an authorized JD dealer
I do dirt work as well and again, never in FW Assist. About the only thing I use FWA for is drawbar pulling something heavy like pulling a stump.
Besides FWA eats up tires as well. Just put new shoes on one of my M's. 4 radial R1's mounted here at the farm was 5 grand.
/ fel loader oversize results #3
As 5030 said - unless you have above average skill and the required tools - it's going to be a trip to your JD dealership.
I've never used 4WD with the loader or, now, my grapple. I use 4WD when blading snow or to traverse my moat in the spring time.
/ fel loader oversize results #4
maybe someone can explain why 4x4 with the loader is bad if the ground is soft/slippery, i used 4x4 constantly with snow piles?
/ fel loader oversize results #5
That must be a big tractor thing. Most compact tractor owners use the 4x4 exclusively and failures are rare.
/ fel loader oversize results #6
This is sparking my interest too. My land is very hilly, and working a lot of dirt on the hill, I am using 4WD all the time, probably 80% of the time the tractor is moving. My average slope is 10%, and it goes up to over 25--I stay off that part unless going absolutely straight up or back. Last night was this 22 ton load of dirt down to the backyard. So is using 4WD on dirt going to cause me problems ?
/ fel loader oversize results #7
Is a John Deere front end really that weak? I’ve had my New Holland boomer 30 almost 9 years now and it spends almost all its loader time in 4wd.
If one dig into a pile destroys the front end, then I’m really glad the John Deere dealer I went to when I bought my cut wouldn’t give me the time of day and I went else where.
I’ve taken my front end apart to replace oil seals, and other than really big sockets it didn’t take much specialized tools. Granted I didn’t have to set lash and offsets for a new set of gears.
/ fel loader oversize results #8
I guess it's because my Kubota M6040 is pretty heavy - 10,100 pounds. And probably because it has R-1 tires. I've never needed/used 4WD when using my bucket or grapple. I have all the necessary traction in 2WD. And I do not run in 4WD simply because the tractor has that option.
There are times when plowing snow or doing major driveway modifications that I need/use 4WD. Otherwise - I plow my yard, mile long gravel driveway and mailbox area in 2WD.
/ fel loader oversize results #9
My Branson 8050 is 10,000# it's in 4wd quite a bit, almost all the time when plowing snow.
On the farm the NH 6050 and the CIH Puma are the primary loader tractors and use 4wd much of the time.
/ fel loader oversize results #10
/ fel loader oversize results #11
I have a JD 1070 which is a younger and slightly larger relative of your JD. It is very important to use a counterweight on the back end of the tractor when lifting heavy loads with the front loader or forks. It reduces the load on the front axle and keeps stress off the front axle. I built a counterweight that is 750 - 1200 lb depending on if I hang suitcase weights on it. I use that or the backhoe. If neither is on the tractor, I avoid using 4WD when picking up something really heavy. If I have to move something really heavy, I plan ahead and do it with weight on the back end. The front axle is not designed to carry the load and the entire weight of the tractor if you raise the rear axle off the ground and try to move a load. Sorry to hear you broke the machine while learning. I was lucky while learning 25 years ago; nothing broke while I did it wrong. I'd look for a salvage tractor and try to buy the whole axle as a unit. The whole series of that tractor axle will likely fit - look at JD parts diagrams.
Thanx for come back ,failure as I see it is because overload on front axle. Rear axle came off of ground(too large load in bucket). All power transferred to front axle. That being said front axle under designed for loaders. Unit is a yanmar tractor under green paint. As far as repairs go will attempt it myself, have been mechanic most all of my life. Has anybody done the shimming of gears for engagement?
/ fel loader oversize results #13
So the issue is NOT 4wd. It is no rear weight and overload enough to pick up the rear if the tractor.
Yes and no i am carrying 200lbs ballast in each tire along with titan weight box on 3 point with 350 lbs ballast weight in it. Looking backward 66 loader bucket is too large for tractor. My mistake is using 4wd on dry hard ground , iwas backing out when lost rear traction jd 790 frontend a weak link. Have used a massey the same way same conditions and had no problem. A lot of problem was my mistake.
More Info coming soon (A66738)
More Info coming...
2014 FORD F-150 (A67714)
2014 FORD F-150...
2004 John Deere 8320 (A63688)
2004 John Deere...
1988 GREAT DANE FLATBED (A67714)
1988 GREAT DANE...
Hydro-Ax 721E Articulating Mulching Forestry Tractor/ Land Clearing (A66734)
Hydro-Ax 721E...
2015 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2015 Autocar...
