Case DX35 Hydraulic Squeal
/ Case DX35 Hydraulic Squeal #1
jletson
Case DX35
I have a 2008 Case DX35 that has developed a hydraulic squeal. It seem to be coming from the left side of the engine around the hydraulic filter but it is hard to isolate since it only does it when the tractor is in motion. I have replaced both filters and the issue has not improved. I can operate the front end loader without the squeal but it is slower than normal as well as the rear lift. The steering is also slow. If you have had this issue before let me know what the resolution was.
/ Case DX35 Hydraulic Squeal #2
Lower the 3 point hitch a bit from the full up position. If the squeal goes away the hitch follow up linkage needs adjustment.
I tried that and it didn't change anything. It pretty much only does it above 2000 RPM's while moving. No noise at all sitting still. Do you have any other suggestions?
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
2011 Caterpillar 420E Backhoe (A64194)
2011 Caterpillar...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
(10) New CATERPILLAR Keys (A65579)
(10) New...
1996 International 4700 (A64127)
1996 International...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - Tier 2 - Irrigation Takeout (A63689)
Kubota V3600-T-E2...
