Case DX35 Hydraulic Squeal
   / Case DX35 Hydraulic Squeal #1
jletson
Case DX35
I have a 2008 Case DX35 that has developed a hydraulic squeal. It seem to be coming from the left side of the engine around the hydraulic filter but it is hard to isolate since it only does it when the tractor is in motion. I have replaced both filters and the issue has not improved. I can operate the front end loader without the squeal but it is slower than normal as well as the rear lift. The steering is also slow. If you have had this issue before let me know what the resolution was.
   / Case DX35 Hydraulic Squeal #2
Lower the 3 point hitch a bit from the full up position. If the squeal goes away the hitch follow up linkage needs adjustment.
I tried that and it didn't change anything. It pretty much only does it above 2000 RPM's while moving. No noise at all sitting still. Do you have any other suggestions?
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
Skid steer auger plate (A50322)
Skid steer auger...
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
HYSTER H50FT FORKLIFT (A52472)
HYSTER H50FT...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
