48" Brush Hog Re-Assemble
/ 48" Brush Hog Re-Assemble #41
Re: 48" Brush Hog Re-Assemble
KentT said:
Resurrecting this one, once I found it...
Can anyone tell me the size of the 4 bolts on the stump-jumper for the 48" rough-cut, two which hold the blades and the two that serve as stops?
Are they 5/8"? How long?
5/8 inch diamter, 11 threads per inch, 2 inches long (threaded part of bolt).
/ 48" Brush Hog Re-Assemble #42
Thank you sir! I'll pick up some Grade 8's to prepare for this mod too...
I doesn't hurt if they are a bit too long as there is plenty of room behind the hub. Just remember that if there is too much non-threaded area, the bolt won't go in far enough.
Another thing... if you ever place an order with Power Trac for anything, add in a few of the bushings that the bolt goes through inside the hole in the blade. About every other time I toss a blade, I cannot find that bushing.
/ 48" Brush Hog Re-Assemble #45
Have any of you ever thought of taking a 5/16”-3/8”piece of heavy gauge steel pipe, and welding it on the blade. The bolt head would then be on the inside of this pipe so that the blade would not come around and hit the bolt head; instead, it would hit the pipe.
Even better, have a local machine shop make two rings the thickness of the bolt head, then chamfer the outside of it. This way the blade will glide over it when it hits. Just an idea:unsure:
I've thought about it, but I'm worried that the blade would eventually beat the pipe into a crushed form and crimp the bolt head. I've also seriously thought about taking the drum off, shortening it by a couple inches so that the blades would ride higher. Then, I'd remove the blades and install "normal" bush hog blades that are of the gull-wing design. If those blades spin around, they miss the other blade's mounting bolt. Gee, what a concept! :ROFLMAO:
/ 48" Brush Hog Re-Assemble #49
That's why they're called Bush Hogs and not brush hogs like the cheap imitations. Everything else is just a rotary cutter. Might as well call all tractors mahindras. ;)
/ 48" Brush Hog Re-Assemble #50
Haha a Mahindras, i had to grab a Kleenex to dry my eyes. :)
I've eyed those type of blades, more than a few time but would have to move the mowing deck upwards to make room for the drop from the blades.
/ 48" Brush Hog Re-Assemble #51
I carry a hammer. Lots of ideas entertained over the years. None really worked without serious modification.
I wonder how just picking up a small 3pt brush cutter with "the good blade setup", removing the 90 degree gearbox and just putting the hydraulic motor on there with a lovejoy would work?
But what fun would that be VS taking a torch to the existing one and making it more better yourself? :unsure: 😛
Yeah, I'd have to shorten the drum AND the shaft inside the drum to make it work.
/ 48" Brush Hog Re-Assemble #56
It would be nice if PT sold them like this.
/ 48" Brush Hog Re-Assemble #58
That's what I'm talking about. Is that a converted unit?
I just looked for brush cutter pieces on the internet that would work; stump jumper, blades, and bolts. Then just retro fit things.
/ 48" Brush Hog Re-Assemble #59
Maybe I could make up packages of these things so that other PT 1430 owners could just buy it and bolt it on.
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
Gehl RS6-34 (A64119)
Unused 2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 Unused...
MechMaxx Grinder Betsco Flail mower
MechMaxx Grinder...
2009 HEIL CRUDE PUP TRAILER (A67714)
2009 HEIL CRUDE...
2015 CTS (A67714)
2015 CTS (A67714)
