Backhoe NEW MT225S owner....mechanical thumb issue
   / NEW MT225S owner....mechanical thumb issue #1
kormidoit
Lake Almanor, CA.
2021 LS MT225S, 2003 Kubota BX2200
The mechanical thumb appears not to be adjustable the way it was installed....take the adjustment pin out and it only drops down 2 inches from folded up position. There are three holes for further adjustment but two tabs at the bottom are prohibiting the thumb to fold out any farther. Any suggestions ?
BTW....Great Tractor. So far.
Apparently cant load the photo. Sorry. I'll call the vendor.
   / NEW MT225S owner....mechanical thumb issue #4
Could it have been installed upside down? So the tabs are at the top and not the bottom.
Just grasping without seeing the setup
thumb3.jpgCalled the dealer and sent them pics....the tabs at the bottom need to be ground 1/4 inch to clear the bottom of the adjustment 'sleeve' as it were. Dealer said they would do it...but I advised I could take on that project...installation of thumb by dealer was correct. Just forgot to ground these tabs for proper rotation of the thumb for adjustment.
   / NEW MT225S owner....mechanical thumb issue #6
That's good news.
I do wonder why there are tabs in the first place if they are too large and have to be ground off.
Good question. In the instruction manual for the LB1300 it shows the schematic of the "optional" thumb, part number IMBH90....it shows the tabs at the bottom of the sleeve part #2. Pin #5 sets the tube where the tabs are into the base of #3. when seated, the tabs bind...& don't allow the sleeve to rotate up to allow adjustment. I suppose if I moved the sleeve up to the second hole on the base #3 it might rotate and allow rotation.
So, I figured it out....no grinding tabs. Pulled pin #5, moved the sleeve up to the middle of the thumb #3 to the holes and reinserted the pin #5.....now the thumb is adjustable up or down....and it forms a triangle for better strength. I am pretty sure that the reason they mounted it was for stowing...flush to the boom.
   / NEW MT225S owner....mechanical thumb issue #9
I'm just curious, is a hydraulic thumb available as a factory installed option on LS backhoes?
Don't know. I am fine with the mechanical. Moved boulders today...worked just great.
   / NEW MT225S owner....mechanical thumb issue #11
Glad you got it figured out.
Me also.
   / NEW MT225S owner....mechanical thumb issue #13
If you don't mind, how much was the thumb for the 1300 bh ,my dealership asked if i wanted it at the time of sale. I believe he said it was a addition of 500.00 dollars. I got a set of forks instead for the loader. I didn't think the thumb would be useful, and have changed my mind since then.
My dealer in Nor-Cal charged 450. 00. Dealer in Reno said it was 250.00. I have used it mote than the FEL.
   / NEW MT225S owner....mechanical thumb issue #15
Thanks for the info, i was hoping to aquire the thumb and install my self, 250.00 seems ok to me , just prefer to install my self gonna have to work that out with the dealer i guess, thanks again
   / NEW MT225S owner....mechanical thumb issue #16
Is the thumb hydraulic or stationary?
   / NEW MT225S owner....mechanical thumb issue #18
how does a mechanical thumb work? is it a set and forget type thing? Been researching LS tractors for a couple of weeks, which brought me back to the forum... :)
Never mind.... found it on youtube. Never knew a mechanical thumb even existed.. :)
I really LIKE it....works Great...it's just mechanical...three length setting and a setting to stow when traveling.
   / NEW MT225S owner....mechanical thumb issue #20
I paid $285 for the mech thumb here in Pennsylvania. I just did my 50 hour service (at 65...shhhh) and I am getting ready to install the thumb that sat in my shop all winter. I'm glad I checked here before starting. Thanks for the discovery, kormidoit.
HOMEADE 8' X 22' TRI-AXLE TRAILER (A60430)
HOMEADE 8' X 22'...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A59228)
2010 Turfco...
2001 John Deere 6210 (A60462)
2001 John Deere...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
