How big is that pin?
/ How big is that pin? #1
Dave from GA & KY
Live in GA farm is in KY
Kubota M7060 Kioti CK35
I have an M7060HDC and have lost the pins in the 3 point telescoping stabilizer bars. I'd like to replace them with some big spring clip pins in stead of the drop-in/cotter pin type that came with it. Anybody know of the diameter/length needed, or even better a source for some pins that'll fit?
Thanks in advance!
/ How big is that pin? #2
I'm not sure on the size, but my favorite place is McMaster Carr...
/ How big is that pin? #3
If you don't want the std Kubota parts, go to your bolt stash and find a bolt that mates well with the hole. Also measure the O.D. of the telescoping bars. There's a fair chance that other mfrs pins (spring loaded) for the same purpose will work . My MF 2660 clips have heavy pins that go through the stabilizer bars and then spring loaded clasps that snap down over the bars as keepers once you are happy with the position. Those fit many models of Massey tractors. Take your bolt and measurements and saunter in to a couple of other brand dealers. You'll probably find some substitutes.
/ How big is that pin? #4
What are you doing that causes the pins to be lost? I've had two different tractors out here for almost 40 years and never lost a stabilizer pin. Mine are the standard pin with a hair pin keeper.
Drop the pin down from the top and pull the hair pin ALL the way thru.
  • Good Post
Reactions: JWR
/ How big is that pin? #5
I use PTO pins
/ How big is that pin? #6
OK - I just now pulled the pin on one of my stabilizer bars. It's 1/2" in diameter and 3" long from the end to the welded on washer. The "hair pin" hole is hard to see - there on the end.
/ How big is that pin? #7
OK - I just now pulled the pin on one of my stabilizer bars. It's 1/2" in diameter and 3" long from the end to the welded on washer. The "hair pin" hole is hard to see - there on the end.View attachment 693200
Far more likely to be 12mm than 1/2". There's very little on that tractor chassis thats not metric. 1/2" may be too big for the holes in the bars.
/ How big is that pin? #8
Close enough for government work.., like I said , go to your bolts stash and find one of known size that fits. Go from there. Whatever is used should be pretty hard steel as those things can take quite a beating, esp when using heavier implements that bounce from side to side (like my 7ft Bush Hog does.)
Perfect! Thanks for measuring them oosik! My tractor is up on my farm and I couldn't get to it right now to get a measurement. What am I doing that's causing these pins to be lost?... Aging! :) I don't know how many times I've laid the pin on the top of the tire or somewhere on the 3 point or implement and driven away. Usually remember it and can backtrack and find it, but not always ;).
These pins are $20 each at a kubota dealer. I Found these 12mmX80mm (.47"x3.12") on Amazon, 2 for $11.99. Just ordered them so haven't tried them yet, will let you know.
Uxcell shaft locking pin :
/ How big is that pin? #11
I lost one very quickly when the tractor was new, dropped in a 1/2" bolt . Fumbling around trying to put the hair pin back in the remaining factory pin led me to replace it also. Those 2 bolts are about 8 years old now, go figure.
Those of you that use a bolt and lock nut for this, how long does it take you to change implements?? What a pain to remove & replace.
I feel the factory pin with the cotter pin in it is a pain getting the cotter pin in & out and holding onto it. I hope those spring clips I found on Amazon work, super quick & easy to remove & replace without dropping any small pins in the high grass!
/ How big is that pin? #14
My pins for the stabilizers have a keeper chain. Held in place by gravity. Never have had one come out....yet.
/ How big is that pin? #15
Same on my tractor. I was always losing the R style cotter pins though. I now just don't use cotter pins anymore. The gravity keeps the pins in place.
/ How big is that pin? #16
No nut! Just adjust the position and drop it in. One bolt is 3" and the other 2 1/2" and like I said, they stay in there where the factory pins are almost top heavy and assured to fall off without the little PIA hairpin that the heavy brush I mow will remove promptly.
Wow, I must abuse my tractors. My little Kioti has keeper chains and drop-in stabilizer pins and I've lost the entire stabilizer, chain, pin, & all on that. Twice! I bushhog blind through 8' high brush & saplings where I need a kevlar shirt to keep from being shreaded by multi-flora rose and blackberries.
One day I took a break and upon inspection it looked like half of my 3 point hitch was missing. I had a short sleeve shirt on and looked like I'd been attacked by a dozen rabid house cats. Had to quit & rebuild. Pins, cotter keys, & parts scattered all over only half of which I found. After ordering my replacement parts online & rebuilding I started taking duct tape and wrapping any spot on the 3 point hitch that has a pin. Works great!
/ How big is that pin? #18
I too work on tall brush and so far have only lost the cotter pins for the stabilizer pins.
Haven't had the pins actually come off the stabilizers once.
/ How big is that pin? #20
The round ring flip type are called "lynch pins" and come in several sizes. Always take an example pin to get the right size.
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
Horse Weathervane (A61569)
Horse Weathervane...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
1991 INGERSOLL RAND DD-24 SMOOTH DBL DRUM ROLLER (A62129)
1991 INGERSOLL...
