How big is that pin?
   / How big is that pin? #1
Dave from GA & KY
Live in GA farm is in KY
Kubota M7060 Kioti CK35
I have an M7060HDC and have lost the pins in the 3 point telescoping stabilizer bars. I'd like to replace them with some big spring clip pins in stead of the drop-in/cotter pin type that came with it. Anybody know of the diameter/length needed, or even better a source for some pins that'll fit?
Thanks in advance!
   / How big is that pin? #2
I'm not sure on the size, but my favorite place is McMaster Carr...
   / How big is that pin? #3
If you don't want the std Kubota parts, go to your bolt stash and find a bolt that mates well with the hole. Also measure the O.D. of the telescoping bars. There's a fair chance that other mfrs pins (spring loaded) for the same purpose will work . My MF 2660 clips have heavy pins that go through the stabilizer bars and then spring loaded clasps that snap down over the bars as keepers once you are happy with the position. Those fit many models of Massey tractors. Take your bolt and measurements and saunter in to a couple of other brand dealers. You'll probably find some substitutes.
   / How big is that pin? #4
What are you doing that causes the pins to be lost? I've had two different tractors out here for almost 40 years and never lost a stabilizer pin. Mine are the standard pin with a hair pin keeper.
Drop the pin down from the top and pull the hair pin ALL the way thru.
  • Good Post
Reactions: JWR
   / How big is that pin? #5
I use PTO pins
   / How big is that pin? #6
OK - I just now pulled the pin on one of my stabilizer bars. It's 1/2" in diameter and 3" long from the end to the welded on washer. The "hair pin" hole is hard to see - there on the end.
   / How big is that pin? #7
OK - I just now pulled the pin on one of my stabilizer bars. It's 1/2" in diameter and 3" long from the end to the welded on washer. The "hair pin" hole is hard to see - there on the end.View attachment 693200
Far more likely to be 12mm than 1/2". There's very little on that tractor chassis thats not metric. 1/2" may be too big for the holes in the bars.
   / How big is that pin? #8
Close enough for government work.., like I said , go to your bolts stash and find one of known size that fits. Go from there. Whatever is used should be pretty hard steel as those things can take quite a beating, esp when using heavier implements that bounce from side to side (like my 7ft Bush Hog does.)
Perfect! Thanks for measuring them oosik! My tractor is up on my farm and I couldn't get to it right now to get a measurement. What am I doing that's causing these pins to be lost?... Aging! :) I don't know how many times I've laid the pin on the top of the tire or somewhere on the 3 point or implement and driven away. Usually remember it and can backtrack and find it, but not always ;).
These pins are $20 each at a kubota dealer. I Found these 12mmX80mm (.47"x3.12") on Amazon, 2 for $11.99. Just ordered them so haven't tried them yet, will let you know.
Uxcell shaft locking pin :
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
2022 Chevrolet Tahoe SUV (A55758)
2022 Chevrolet...
Shell Vintage Decorative Fuel Pump (A55758)
Shell Vintage...
2014 Walker Walk-Behind Vibratory Plate Compactor (A55787)
2014 Walker...
40' Sea Container (A50775)
40' Sea Container...
2011 MACK CHU (PINNACLE) (A55745)
2011 MACK CHU...
