Help with washer fluid ballast.
/ Help with washer fluid ballast. #1
brokeasajoke
320dtc
Tire came off wheel and I lost my fluid the other day. The tires have washer fluid for ballast in them. My question is do I put straight washer fluid or mix with water and what ratio? Once or twice a year it may hit single digits here but is often in the teens in winter. Thanks.
/ Help with washer fluid ballast. #2
For your temps. 0F fluid will be just fine!
You don't dilute it in your car, so why would you dilute it in your tires?
This time of year, you should be able to find it on sale at end of season prices.
Most I see around here is -25. I have plenty of antifreeze but hate to use it in case of another spill cause its probably ethylene glycol.
/ Help with washer fluid ballast. #4
Nothing wrong with -25F WWF.
/ Help with washer fluid ballast. #5
Is your tractor inside stored, or outside stored?
Outside or unheated shed.
/ Help with washer fluid ballast. #7
When I loaded my tires, I bought a barrel of methanol and mixed it with 1.5 parts water. That gives about a -18f freeze point. I needed about 125 gallons to fill my rear tires, so it was easy to just pump from a 275 gallon tote.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
208735 (A60430)
208735 (A60430)
Sdlanch 20'x20' High End Carport (A60463)
Sdlanch 20'x20'...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2000 Sakai SV505 (A60462)
2000 Sakai SV505...
