Draining my backyard swamp
/ Draining my backyard swamp #21
I would wait until the ground dries out. The work you need to do will require a a lot of digging and smoothing and that is much easier with drier soil. The swale to the creek would seam to be the right way to go at the least cost. You might dig a plastic 55 gallon drum into the low spot and use a sump pump to speed up the drying of the soil as a temporary solution to the water problem. This is the dry well that you were referring to earlier.
I would avoid the rock lined type of swale. They idea sounds great but in short order the plant life that will move in will become ugly. Spraying it with a herbicide to keep up the nice look will be expensive and hard on the environment.
The use of leaves, tree trunks and mulch, while a way to build up the soil will result in a soft mussy yard for many years to come.
To remove the soil that you now have in place and add fill dirt then replacing the top soil sounds like a good solution. Along with the use of the swales to to move the water. Also the use of a subsoiler would seam be a good thing to do.
I would look into buying a box blade to move and level the soil. This is not an easy task with just a front end loader.
Also take a look at the elevation of the rest of your yard. Just to make sure that if you raise the level of the swamp you will not just move the water to another spot in the yard.
With the creek running across the yard have you checked on flood insurance for your house?
/ Draining my backyard swamp #22
from the pictures it doesn't look like you have a surface water problem it looks like you have a subsurface water problem.....meaning high water table......that will fluctuate throughout the year and if that is the case then I'd recommend talking to the locals and see what they do as the local soil permeability comes into play with how well the water will run through it....if it's sandy then water will run right through it and swales should work well but if it's clay the waters not going to flow and you'll need a different solution.......Jack
I would lean in that direction, is there a low spot where you can send the water to? If you do, my first plan would be to dig (or have someone dig) some trenches to the low spot (every 20'), then put in some geotextile cloth, some gravel, then drain tile, then more gravel, then wrap the geotextile cloth over the top of the gravel and backfill with dirt on top.
Here is someone showing how they do a high end system to do what the OP wants to do:
Aaron Z
Thank you everyone for the input, lots of good information. I think my best course of action will be to let it dry as suggested, and then I'll come through with a sub soiler to improve the compaction issue. Finally I'll dig another trench down to the creek and run a tile drain like in that video. The creek isn't big enough to worry about flooding my house, it's more of a swampy stream a few inches deep and this is at the wettest part of the year.
/ Draining my backyard swamp #24
You have what you have. I simply don't understand, with all the building codes, how it is acceptable to build a house that requires a sump pump, to keep the basement dry. That would seem like a totally wrong place to build a house, if you ask me. At least, one with a basment or toilets.
/ Draining my backyard swamp #25
If you don't build a pond, I would re-contour the yard so there was no flat part. Make it gently rolling with the low spots draining to the creek. No flat ground = no standing water.
Bruce
/ Draining my backyard swamp #26
I have water draining from up the mountain. I put in a big swale in order to move that much water.
Meant to handle a 4"/hour rainfall (and yes, it has been tested).
At the widest it is about 5 feet across and 3 or so feet deep with a fan out to the back of my yard.
No more flooding where I need it to be dry.
Spent a lot of time watching the water flow and calculating how much water per acre and through the pipe under the road.
/ Draining my backyard swamp #27
Six decades ago I worked for a builder. I was the kid they sent into the percolation test pit to dig a 5-gallon hole and pour a bucket of water in it. I would then stick a ruler in the hole and then call out as the water receded each inch. About 20 years ago when they did a perc test for my new septic system, the engineer placed a 5 gallon pail with holes in the sides into the hole and slowly decanted the water into the perforated bucket. The engineer later explained that dumping water into the hole drove the small particles between larger particles blocking passages and causing it to take longer to recede. I am sure they have become increasingly sophisticated performing the test and can now get swamps and ponds to perc.
/ Draining my backyard swamp #28
An experimental approach with your various materials seems unnecessary. Since it looks like you do have runoff on the perimeter, start scraping, hauling, shoveling onto tarps and dragging, whatever it takes to steal from where it's already sloping away, to fill in the low area. The grass will come in; it will look like the rest of the yard. This conservative advice is coming from a person without a tractor (I do have a Ditchwitch).
/ Draining my backyard swamp #29
My entire backyard has had standing water since I moved into my house in December. I suspect it's primarily due to compaction, as the previous owners had a good 15+ trees cut down back there. The standing water seems to be in all the ruts created by the tree trucks. Fortunately for me, they left all of the logs stacked on the edge of the yard. Unfortunately, they're far too big for a chipper.
My plan is to scrape the entire back yard down about 8 inches or so with my FEL. Next I'll cut the logs into 4 inch strips, and use them like pepperonis to fill in the excavated yard. The next layer will be mulch and other compost type material, and then I'll finally cover it all with the dirt I originally dig up. Any input on this idea would be appreciated, not entirely sure if it's the best way to do it but it's the best way I can think of using the materials and equipment I have.
View attachment 691055View attachment 691056
Just cut a swale so the water can run off. Digging up all the topsoil is not a Good idea.
/ Draining my backyard swamp #30
When we built our arena we knew we had a water problem and I didn't have a backhoe so hired an operator to dig a 2' deep trench along the high sides and put 8" perforated drainpipe in the bottom sloped everything to the low side and filled the trench with about 1" drainrock. I call it a curtain drain. Solved all the water problems flowing down hill toward the arena. A swale may work well for you in this situation.
/ Draining my backyard swamp #31
Yeah good advice in here so far. Since you appear to have modest elevation to work with, all you truly need is to contour the land so that nothing puddles and it all gently flows away, down your swale.
Your original idea to put wood underground and cover with mulch would have been a total disaster of soupy black muck in a couple years. If you do import material to raise the land, go with sand or sandy loam.
But other people from NC have been on here complaining about the excessive rainfall and wet conditions. Since you just moved it, I would give it a bit and learn the seasonal nature of your property.
/ Draining my backyard swamp #32
The drainage swale you dug should work, provided it is in the low spot of your "swamp". Once it dries out a little, plant some sort of grass seed over the whole area. Vegetation soaks up a ton of water. Depending on where you live, a creeping kind of grass would be great, because it will eventually grow into the drainage swale and protect it from eroding further.
Nice pupper dog!
/ Draining my backyard swamp #33
I did start a swale yesterday, and it's difficult to see but the yard does have a gentle slope towards a creek behind the yard. Would the swale along one edge be enough if I can fix the compaction issue? Or do I need a drain through the middle as well? I was also thinking about a dry well. My thought behind burying the disks was to raise the overall level of the yard, but I think it would require several loads of mulch and fill dirt to prevent the lumps. I'll get some better pictures today to try and show the whole layout. View attachment 691085View attachment 691086
Unless you always want to have a muddy ditch through your yard and as you have a creek to drain it to, this looks the perfect application to install Hydroblox. We've used them successfully to drain flooding areas and they work better than any french drain and better than most ditches, in my opinion. Plus, you can have a perfectly smooth dry lawn then.
Just search for Hydroblox videos in YouTube or go to Drainage Stormwater | HydroBlox, Inc. | Bradford Woods
You can install these yourself in short order.
/ Draining my backyard swamp #34
Let the swale do the work of starting the drying. Here in NC we just had the second wettest winter on record (just 0.03" shy of a new record). Things are finally drying out around here. Depending on where in eastern NC you are, you may also be dealing with clay near the surface. The suggestion of the cereal grasses to break up the compaction is a good one for our area but you may have to do it over a number of years if the clay is close to the surface.
If you find the single swale isn't cutting it, you can then move onto the second one up the middle or do a buried drainage line (or lines) through the center if you don't want to see the swale there next year.
In digging the swale, I hit the clay layer about 8 inches or so below the surface. I have seen substantial improvement in the two days since digging it though, even now water is still flowing through it pretty good. After the middle parts dry I'm going to see if I can regrade with a box blade. The bottom part of the yard has a sizeable slope, while the top part is flat. I think if I can grade it all and make a continuous gradual slope, while grading out the current ruts, that might be sufficient. If it's not, then I'll add a drain, something like the hydroblox maybe. Finally the cereal rye to help the overall long term aeration of the area.
/ Draining my backyard swamp #36
I know you want the area fixed now, but the key to success, in this case, is patience. Document the problem areas with photos and sketches and then wait for the area to dry out. THEN fix the problems. When you drive on wet areas, you're just adding to the problem with more compaction. The drainage swale is a great start, now leave it alone, and let the area dry out. Grade the area carefully after it dries out. Grade so that the yard is sloped to drain to a natural drainage point. If you have to, bring in loads of additional topsoil to achieve the grading and ground level you need to fix the area permanently. Using the logs as fill material is not going to work in the long run because they will decompose at different rates and you'll end up with soft areas that will settle and sink. One of the problems with wood is that some trees may contain naturally occurring allelopathic chemicals that theoretically could be leached into the soil and affect plant growth. My advice would be to either have the logs chipped and use the chips as ornamental ground cover, burn the logs, or use them as firewood.
With projects like these, sometimes your worst enemy is your own enthusiasm to fix the problem. Relax. The area will still be there after it dries out and you will be far more successful fixing it when you can work on the area without worrying about getting stuck, further compaction, etc.
/ Draining my backyard swamp #37
We recently went through this. If you want to keep an area dry, you need to stop the water flowing in from uphill, and provide means for rain that falls on it drain away as well.
We had water draining off the driveway into the garden area, and threatening to wash out a steep rock path. The uphill trench ended up being about 2' wide and 3' deep, with a 6" layer of drain rock (1"-3" smooth river rock). A drain pipe was then laid in, wrapped in landscape cloth with more drain rock included inside, and surrounded and topped with more rock; the very top layer of rock is road rock to keep things in place. The drain was led and daylights downhill. This has been working like a charm this year, despite a lot of rain. There's sometimes an stream coming out of the drain like a garden hose running hard - a lot of water that no longer saturates the 30x30 area south of the house.
/ Draining my backyard swamp #38
/ Draining my backyard swamp #39
Firstly dont bury logs. When they rot you will have big deep trenches for ages. Catch the water at the highest area and use drains or pipes to move it down. Do same for roof gutters. If you cant afford tons of fill, why not build a dam as a feature duckpond. The excavated material can be used on the rest of the areas. When using piping get as big a diameter as possible with smooth sides and direct it towards nearest drain. Piping helped reduce our problem
Mulga88 Australia
Thank you everyone for the excellent advice. The swale is already doing wonders, and I'll find some other projects for my new tractor until it dries out enough to continue working the yard.
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
2011 Jeep Grand Cherokee Laredo SUV (A64557)
2011 Jeep Grand...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2012 FORD FOCUS SEL (A65054)
2012 FORD FOCUS...
