Kubota F series
/ Kubota F series #371
Hi all - I posted several questions about F-series attachments in the Attachments section, but I see this thread has recent activity and wondered if anyone could help me out. Thanks in advance! Geoff
/ Kubota F series #372
Here's a used 60" deck: Used Kubota RCK60PF36
Give Messicks a call. They will have their parts dept cross reference part numbers for you to verify what fits. My guess is this deck will work, but not 100% sure.
/ Kubota F series #373
Thank you. I actually inquired on that one today, but here's what I got back. I don't think the reply makes sense, since I'd be choosing whether to have the quick hitch or the mower mounted (not both at the same time).
"Thank you for reaching out. Unfortunately your F2260 takes a completely different Quick Hitch (F5211) then this mower would, so it would not hook up properly to your mower. Let me know if you have any other questions."
/ Kubota F series #374
Give them a call on Monday, ask for Shannon, he's very helpful. Like you said, you don't use a quick hitch to mount the mower decks. There's another deck on there for my 2880 I'm trying to buy from them!
/ Kubota F series #375
Will do - thanks!
/ Kubota F series #376
There was an F3680 for sale with a 72” rear discharge deck, low hours AND a optional flail mower, and it was cheap. Just one problem, it was in Great Britain :(
/ Kubota F series #377
Will do - thanks!
That's a good price assuming it fits (Messicks can easily check that)! Hopefully it comes with a drive shaft also?
I have not priced out 60 inch decks, but a just a 72 inch replacement deck shell alone will cost over two grand.
I wouldn't want to mess with a quick hitch for a mower deck in a Kubota F - the original factory setup works fine.
/ Kubota F series #378
Do the other implements, blower, flail mower, etc. hook up fairly easily ?
/ Kubota F series #379
Yeah, I’ve seen some across the pond...something made me think it wouldn’t be worth the shipping. 😂
/ Kubota F series #380
Thanks - I did ask them if it comes with a shaft. I’ll try calling tomorrow.
Agreed on the quick hitch and deck. My idea is to use the quick hitch for spring clean up (rotary broom), then take it off and go to mower for the summer. In the fall, go back to quick hitch for clean up and then alternate between the broom and blade through the winter depending on how much snow we get in each storm (Utah). I haven’t got to try sweeping snow with the broom yet but I’ve seen videos and it looks pretty impressive at getting it down to bare concrete. The blade pushed a lot of snow this winter, and I could stack it about 4’ high. That was before I realized I had the lockout blocks installed that prevented the blade from raising more than about 8”. Next winter should be fun - I bet it’ll stack it to 6’ with full range on the blade!
2018 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2018 FORD F-150 XL...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
2017 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2017 KENWORTH T680...
