Modifying a quick hitch
/ Modifying a quick hitch #1
bdog
Elite Member
Texas
John Deere 6130M
I have a Lee Boss category 3N quick hitch. I believe Lee makes the best strongest quick hitches out there. They are over 1k new. I didn’t pay near that for mine I got it at an auction nearly ten years ago. Anyway I changed tractors and am going to all cat 2. Looking at the specs the lower hooks are identical on a cat 3N and a cat two the only difference is the top hook is 4” higher on a 3N than on a two. Any reason not to cut off the top hook and reweld it on 4” lower?
/ Modifying a quick hitch #2
If it works for you go for it!
/ Modifying a quick hitch #3
I have a Lee Boss category 3N quick hitch. I believe Lee makes the best strongest quick hitches out there. They are over 1k new. I didn’t pay near that for mine I got it at an auction nearly ten years ago. Anyway I changed tractors and am going to all cat 2. Looking at the specs the lower hooks are identical on a cat 3N and a cat two the only difference is the top hook is 4” higher on a 3N than on a two. Any reason not to cut off the top hook and reweld it on 4” lower? View attachment 690614View attachment 690615
If your welds are as good as factory shouldn’t be a problem!!
/ Modifying a quick hitch #5
I'm surprised that the top hook isn't adjustable on that. Anyway, there shouldn't be an issue with lowering it 4".
/ Modifying a quick hitch #6
Why would you buy a QH whose top hook is not adjustable..... Since implement manufacturers can not seem to get standard right, seems a little counterproductive....
Dale
Dale
If any of my implements are not to standard I modify them so they are. Having to adjust the quick hitch defeats the purpose.
/ Modifying a quick hitch #8
I have advocated that many times in many forums, but adjustability of top hook seem to be "standard" on most all QH's... The height/style of hook just seems to be something manufacturers can not agree on even that it is a standard...
Dale
/ Modifying a quick hitch #9
I did the same. But his point is still valid: I moved my top hook height to one implements height (EA 8' grader blade) and then made the other implements to fit that height (which is usually the easiest to mod). If I had a non-adj top hook, then I might have had to modify the EA grader blade as well.
I bolted my top hook and have never needed to change it since then.
A QH is a "pay me now" or "pay me later" kind of deal. Fool with it once (mod the implements) or be condemned to fooling with it each and every time I want to change an implement forevermore. I'm dang glad I chose the former.
/ Modifying a quick hitch #10
Dale
Cat 2 quick hitches do not have an adjustable top hooks....at least none of the five I looked at, none of them were adjustable.
/ Modifying a quick hitch #11
So how are y'all modifying the implements to fit your QH?
Most of my implements I can back up and latch with the lower links, but the top link always seems to require pulling the top pin, extending the top link and replacing the top pin.
Only 2, maybe 3 implements can I can back up and hook up without some manual convincing.
/ Modifying a quick hitch #12
Cat 2 and 3 implements adhere to the quick hitch standards much better than Cat 1 implements. They are too heavy to move around by hand if you are 1/2 inch off.
Sometimes you can drill new holes. I have a magnetic drill which makes it easy. Other times you may need to cut and reweld the mounting tabs. It is a pain but you do it once and then have a lifetime of easy connections. I guess part of my strong opinion on this is coming from larger tractors. Everything on them is quick hitch. You aren’t wrestling around 5,000 lb implements. The concept of quick hitches not fitting is something I first encountered on smaller tractors.
/ Modifying a quick hitch #14
I modify everything I already own and refuse to buy anything going forward that doesn’t fit.
/ Modifying a quick hitch #16
/ Modifying a quick hitch #17
I wish I could use the top hook, there isn't a position I can use on all my implements. I don't use the hook anymore just the pin on swivel adapter since it doesn't need tools to adjust.
/ Modifying a quick hitch #18
Not all equipment works with quick hitches, I use a shot piece chain at the top connection, easy to hook and un hook
/ Modifying a quick hitch #19
I would look at an automotive type spring hanger shackle to extend the implement reach. drill a hole in the shackle and implement to keep it upright.
/ Modifying a quick hitch #20
Weld or bolt some heavy steel to implement to lower the top connection point
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
APPROX. 6000 GALLON ALUMINUM LAY FLAT TANK (A64278)
APPROX. 6000...
2011 Ford E-350 Passenger Van (A64556)
2011 Ford E-350...
2019 Komatsu WA380-8 Articulating Wheel Loader (A64194)
2019 Komatsu...
2015 ALTEC AT200 MOUNTED ON 2015 FORD F450 XL SD (A67148)
2015 ALTEC AT200...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
