Fuel bowl plastic shrinking?
/ Fuel bowl plastic shrinking? #1
repete
SW Washington
L2550DT IH584-4WD
My neighbor just can by with his plastic fuel filter bowl and the threads and shrunk to the point they look like a pipe thread and it will no longer screw in and seal. I am guessing it to be about a 25 horsepower unit and 2.5 years old.
Is this a common thing?
/ Fuel bowl plastic shrinking? #2
Did he cross thread it and wreck the threads. Some have a o-ring seal also....
/ Fuel bowl plastic shrinking? #3
I also had that problem on a Mitsubishi K3 engine.
Bowl is real close to the engine and my take heat did it in.
Mine was very dark yellow* age tinted as well as shrunken.
While it still threaded on OK, filters no longer would fit in.
Only replacement bowls available were 3 " long but I had to have a shorter 2" one.
I cut a 3" back to 2", capped and sealed it and added a drain cock making it into a separator.
I next added an inline throw away filter for any fines'
Going on about 5 years now and all is fine.
ps; tried some 5-6 different brand dealers to attempt to locate my proper 2" bowl without satisfaction.
* yellow was age related and not from rust.
No, it is the total circumference of the thread. At the end with the O ring seal it is like 4" and at the distant end of the thread from the O ring it is like 3 3/4". Looks like the taper to a pipe thread.
