Two tractors or one - need help deciding
/ Two tractors or one - need help deciding #1
bdog
Elite Member
Texas
John Deere 6130M
I currently have a 4440. It doesn’t have a loader and is two wheel drive. It also has long axles for duals and even with the duals removed is overwidth for hauling purposes. I have owned it 7 years and it has been a great machine at my house which is on 30 acres. I have a tracked skid steer I use for loader work.
I recently bought 330 acres located a little over an hour away. It has some steep terrain and MFWD is needed to get around. Needs there are shredding, blading probably ten miles of roads, cleaning up brush from when we bulldozed these roads, planting some food plots for deer. There are about 40 acres that were once farmed that are grown up now. I plan to turn some of them in to food plots but don’t envision more than 15 or so acres total of food plots. A stout loader is a must as well we feed a lot of corn and protein to the deer and are needing to move 2,000 lb pallets of feed around regularly as well as moving the heavy feeders and deer blinds around. I have been hauling my skid steer back and forth and it is often a pain as I often need to be able to lift heavy things at both places on a regular basis.
I visited with a few dealers and they are offering around 20k trade in on my tractor. A similar sized machine (but not over width for hauling purposes)with MFWD, cab, loader, and a hydro shuttle is going to run around 60k. Alternatively I could buy a smaller machine outright for around 40k. Same out of pocket cost either way.
Trying to decide if I should trade in my 4440 and have one larger machine or keep it and buy a smaller machine?
If I had one larger machine I would likely need to haul it back and forth some but not a lot. This I guess would be viewed as a con but a pro would be it would be more capable in every way. A smaller machine would likely get left at the distant property full time.
I’m intentionally leaving brands out of this but the smaller tractors I am looking at are in the 75 HP range and the larger ones are in the 125HP range.
/ Two tractors or one - need help deciding #2
I would keep it and get a second smaller tractor. That gives redundancy if one goes down and allows more freedom to work different land without having to worry about how to get the tractor there to do work.
/ Two tractors or one - need help deciding #3
I learned to do all my tasks within a certain hp rating (25-35). That let me buy more than one CUT (some 'pre-owned) to reduce changing 3PH or FEL implements. (buckets, flail mower, grapples, etc)
Seat-hopping vs frequent tool changes works for me. I tend to use the smallest tractor for a job, but there's a lot of 'overlap' in abilty & usage(s). When one machine goes down for service or breakage (don't see that much with lo hours/machine) I'm never more than a tool change away from getting the job done. JMHO, YMMV.
/ Two tractors or one - need help deciding #4
Redundancy is ALWAYS a sweet option to have. Especially when there is a bit of overlap in capability.
I agree redundancy is good but the 4440 is useless at the distant property. No loader, 2WD, I doubt it could even make it to half the acreage as there is a large canyon that more or less cuts the property in half. Hauling it would also be a huge issue due to the width. The only benefit to keeping it is use around my house. With my skid steer available for loader work all the tractor gets used for is plowing, planting, and shredding.
/ Two tractors or one - need help deciding #6
I did pretty well shopping for used CUTs in the 25-35 hp range with features I wanted (HST. FEL), <4k lbs 'wet' with FEL for trailering and for $9k- $13k US to play. What my three have in common is being sourced from one brand I've never had issues with out of four. (Shibaura)
IMO the best thing about Deere CUTs is Yanmar power, what put Atomic Four out of biz for sailboat auxiliary power. I'd only avoid engines that rev > 3k rpm, and there's a lot of variety within the Deere brand. That said, I confess to having at least two of everything. (cars, trucks, tractors, mills, lathes, air compressors, welders, etc)
/ Two tractors or one - need help deciding #7
Sounds like you have already answered your question. If I could get 20k off by trading the 4440 in, and was keeping the skid steer, I’d get the bigger new tractor. Just go as big as you can, so you don’t feel like you were wishing for more.
My guess is no matter what you do, the new tractor will get all the seat time. The 4440 will mostly be sittin. Might as well get a nice size frame and the 125HP.
Never seemed to feel like I had too big of a tractor, but many times too small.
/ Two tractors or one - need help deciding #8
I wonder just what it would take to find a modern tractor comperable to the old 4440? It says a lot when a dealer is willing to offer that much on a 40 year old tractor.
/ Two tractors or one - need help deciding #9
Those tractors are well liked, and held their value.
/ Two tractors or one - need help deciding #10
In my way of thinking, you should have one tractor of whichever make suits your fancy, for every implement you use. Getting rid of the 4440 sounds like a good deal, but you could shorten the axles on it and bring it down to legal width, too and keep it. Or you could get a loader for it and carry on.
The dealers told me it was really good I didn’t cut the axles down. I guess many people have and it hurts the value. I thought about doing that and getting a loader for it but still it is 2WD.
It does sound like I have made up my mind to get rid of it but that isn’t the case. I love the 4440 and before I got this distant property I had zero thoughts of getting rid of it. Combined with the skid steer it is a perfect setup for what I do at my house. That being said it doesn’t get much use. Maybe four days a year of plowing and planting and shredding maybe four times a year. Yes it gets used less than ten times a year.
/ Two tractors or one - need help deciding #12
A tractor per implement is nuts! I'd need three! Four when I get a forestry winch. That's $200k of the OP's size tractors. With top and tilt and extendable lower links it only takes me a few minutes to change implements. It takes that long to warm up the next tractor with its dedicated implement. Maybe with 75-125hp tractors it's more work to change implements but as long as they're three point style I don't see why it would. I store my implements in the barn with some on dollies, so part of the time to swap implements is rolling stuff out of the way. Big implements are probably going to be stored outside and certainly not on dollies or with another implement in the way. So you'd just have to back up to them.
Big tractor implements are easy to hook up. They are all quick hitch. The implements are so big and heavy you can’t wrestle them around like you can small tractor implements.
/ Two tractors or one - need help deciding #14
I would keep the 4440. It won't depreciate anymore and some may say it will appreciate in value because it just might be the next Deere collectable tractor to have.
/ Two tractors or one - need help deciding #15
75 is a little on the light side for moving 1 ton skids around in any kind of environment. Running tractors back and forth is a PIA. You can shorten/whack off the axles and if you want and Koyker makes loaders for more in the $5k region, delivered to your farm for a reasonable price, to fit your 4440....a great workhorse and fine Soundguard Cab....I had one on my 4020 (96 hp) with an 8' bucket on it and it did fine......but mine didn't have the Skid Steer quick attach bucket (30 years ago) and I'd surely want that. I am a multi tractor guy since I work alone and no way will I only own only one......like fishing boats....one just won't cover all the bases!
After much thought I decided the 4440 is going. I removed the duals and brought the front wheels in so I could get it on a trailer and cleaned it up. I have owned it seven years and put only 150 hours on it. Can’t really justify owning two. I’m not sure what I will be buying to replace it with yet but something with a cab, loader, and MFWD
2019 Ford Explorer AWD SUV (A66738)
2019 Ford Explorer...
2027 Terext Light Plant (A67714)
2027 Terext Light...
SCAN TO RECEIVE TEXT UPDATES (A65056)
SCAN TO RECEIVE...
2017 Volvo VNL T/A Sleeper Cab Truck Tractor (A66736)
2017 Volvo VNL T/A...
Unused 2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 Unused...
Travel Trailer (A66738)
Travel Trailer...
