Third function install issue
/ Third function install issue #1
Tide2021
LS MT345
Needing some help on a third function install on a LS MT3. The kit comes with a “joint kit” but the instructions never tells where it goes. I’m sure it goes in between the loader and third function valve but I’m not sure of which direction.
/ Third function install issue #2
Just a guess, but either to joint more valves in series or to enable you to attach the new joystick to the old lever?
/ Third function install issue #3
The instructions you need are in the Assembly Manual for the loader. As an example, I have attached this manual for a M7040 with LA1153 loader but expect same or very similar.
Working on the M series ( and other tractor) hydraulics requires great care or the main pump will be destroyed.
Your photo of the page with the joint kit is not clear so suggest you post a photo of the real part.
I suspect it may be a power beyond sleeve for the loader valve. How many hoses presently connect to the loader valve. 6 or 7?
It makes a big difference!!!
Dave M7040
  • assembly instructions LA1153E AI EN 7J417-69171(New Edition).pdf
The instructions you need are in the Assembly Manual for the loader. As an example, I have attached this manual for a M7040 with LA1153 loader but expect same or very similar. Working on the M series ( and other tractor) hydraulics requires great care or the main pump will be destroyed. Your photo of the page with the joint kit is not clear so suggest you post a photo of the real part. I suspect it may be a power beyond sleeve for the loader valve. How many hoses presently connect to the loader valve. 6 or 7? It makes a big difference!!! Dave M7040
Dave M7040
Thanks for the advice. I’ll post up some more pictures when I get a chance. The loader valve acts as a manifold, third function mount directly to it with o-rings in between. I’m in North Carolina but actually found a dealer in Alabama willing to help out , they deal with a lot of larger tractors but haven’t ran into this issue yet. Hopefully hear something back today.
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63118)
2023 Takeuchi TL6R...
Bell 1600 Gallon Nurse Trailer (A63118)
Bell 1600 Gallon...
1820 (A62130)
1820 (A62130)
120 GALLON WATER TANK (A62131)
120 GALLON WATER...
2009 Honda Pilot AWD SUV (A61569)
2009 Honda Pilot...
