Optional Cab from Bobcat for CT2025
/ Optional Cab from Bobcat for CT2025 #1
Snowlan
Halifax, Nova Scotia
Bobcat CT2025
Has anyone ordered Bobcat's optional cab and installed it on a CT2025? My dealer had a CT2025 on the lot with the cab installed, it's the one I test drove. Looks like a factory cab on the outside, but the inside is hard plastic surface and didn't seem to do anything for the noise. It had heat, but no A/C and he wanted $15k CAD more for that tractor. From my shopping that seemed like too much for a cab, factory cabs with AC on other brands cost less to upgrade. I'm wondering how much of that was shop labor and if they will sell the kit for self-installation. I may inquire about that and consider the upgrade once my house is built and the woods trails are cleared on the lot. As expensive as it was, it was still quite a bit less than a CT2535 which is the lowest hp you can order the factory cab on, perhaps that is their game during this time of low inventory.
/ Optional Cab from Bobcat for CT2025 #2
I have the older version. a bobcat CT 225. I purchased a factory steel cab and installed it myself for my tractor. It has heat but no AC. I believe the cab was made by a company called Cozy cab for bobcat and came with a bobcat logo on it. I am very happy with it. all of the glass panels are lined with steel and have prevented many glass breaks because of that. Only negative is that it is a bit loud compared to a factory cab. But it is a very thought out design with doors that are easily removed and have hold opens for more ventilation in summer
/ Optional Cab from Bobcat for CT2025 #3
You’ll be unhappy with the performance on that tractor if the can had AC. It takes 5hp to run an ac property. You’d have one struggling CT2025. There’s a reason they only go on 35hp and up
That's a nice looking setup you have there.
For those interested, my dealer told me today that the CT2025 cab kit rounds off to about $9,000 CAD for someone that is going to order and install themselves. Upgrading the 35hp tractor to the factory cab model is approx $14,000 so that is pretty good savings and all that is missing is A/C which is fine in my climate. The bigger picture is that my tractor price plus the optional cab would be around $31,900 and the 35hp model which is the cheapest Bobcat you can order with a cab comes in at about $41,000. That's pretty significant. Here is a picture of the CT2025 my dealer kitted out with the optional cab. The price with their labor was about another 6k and just not worth it in my opinion so for me it would have to be DIY.
/ Optional Cab from Bobcat for CT2025 #6
New here and bought my ct 2035 open station in October. Have now decided I want a cab and heat. No cab tractors available, couldn't find much on bobcat tractors with the "field cab" except this post. Adding pictures here for others to see and ask questions if they want. It is going on the tractor hopefully this week. Pending projects currently in the shop. I considered building one, but with the cost of materials and time I have, it made sense to buy a cab from the manufacturer.
I don’t mind saying I wish I had a cab today, I was soaked by the time I finished blowing the driveway while there was wet snow falling.
I look forward to hearing how the field cab works out for you. In a couple years I’ll likely compare buying the cab vs trading my 2025 minus the backhoe for a 2535.
/ Optional Cab from Bobcat for CT2025 #8
Someone recommended a snowmobile helmet with a heated visor to me. I wired in a 12 volt socket so could just plug it in. I use ski goggles for now but I was basically a wet snowman after finishing the driveway.
/ Optional Cab from Bobcat for CT2025 #9
We got the cab mounted on Wednesday, fit and finish is great. I installed the hydraulic side of my 3rs function valve while the seat was off. Still was able to get it all on and hooked up in a day. Things to keep in mind is the heater core lines need to be primed with coolant before hooking up for good. Otherwise it's a HUGE air pocket in the heater core. So far I love the cab. I opted to not purchase the insulation package because it was an additional 1k. Figured with the cab and heat it will be a huge step in comfort while using the tractor in the weather. It is louder inside the cab while running the tractor, ear plugs or something for the long days of plowing and working inside. With the windows open it's better though. The front glass tips out a good 6-8" at the bottom and the rear glass is defrost type and opens as well. I added some work lights to the rear upper corners and waiting for a switch for this. I included the pictures inside and also the hydraulic connections to see how tight everything fits. I'll add more later.
/ Optional Cab from Bobcat for CT2025 #10
That’s awesome. Hard to go without a cab once you have one. I too was very surprised at how much noisier it was with the cab on. I spent quite a bit of time trying to reduce the decibel level inside the cab with some success. I cut some pieces of carpet to put on the floor for the winter with some padding that helped. also I bought some 1 inch wide by approximately 3/8 thick foam weatherstripping and ran it along the steel supports all inside the tractor. I also used sound deadening under coating under my fenders and rubberized flashing tape where I could under the seat underneath the tractor to absorb sound. Was able to reduce the decibels inside the cab quite a bit.
/ Optional Cab from Bobcat for CT2025 #11
The sound deadening under the fenders is a very good idea. I think I'll give that a try. I have the runner from mat on the floor already. I may look into some of the under seat insulation stuff as well. BUT not super concerned about it. More excited to just be dry and out of the wind/snow falling out of the trees when out working.
I do hope to have a cab one day, but there is one thing I’d miss - the ability to grab the ROPs and step on the rear tire to swing around to the backhoe. I see the AG tires may not be wide enough, but with the Industrial tires there is lots to fit your foot on.
Everything in life has a trade off….
/ Optional Cab from Bobcat for CT2025 #13
I agree on the trade off. I've ordered wheel spacers for the rear to help with stability. I really wanted the r4 tires bit the dealer and there network didn't have any and from what I've heard months out. I wanted them for tire chain choice. Oh well. Made it work. The ag tire choice maked the tractor considerably narrower at 56".
/ Optional Cab from Bobcat for CT2025 #14
I’m on the verge to buy the same cab for my CT2025 HST. Few questions for you Idahobobcat. How heavy it is? How did you raise it on top of the tractor? Can we make it lighter before raising it by removing windows and doors? Do you have installation instructions in electronic format? Would you mind sending a copy? Thanks. It will help me organizing the installation. Btw if needed I may have access to a nearby shop.
/ Optional Cab from Bobcat for CT2025 #15
I have an older CT235 & would love to have a cab.
Go to an HVAC supply house & buy black closed cell rubber insulation, the type they line ductwork with. You’re also going to need the propriety spray glue for this. Cut to fit, spray glue both surfaces, let it tack up & install insulation. This will help deaden the sound & help retain heat.
Good luck!
/ Optional Cab from Bobcat for CT2025 #16
What about Curtis’ aftermarket cab for Kioti tractors. I was seriously considering buying one for my bobcat 2035, they are almost the same tractors aren’t they?
2009 INTERNATIONAL MA025 SERVICE TRUCK (A66091)
2009 INTERNATIONAL...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
ALLMAND  MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
Unused 2020 Kodiak 4AP Towable Aerator Tractor Attachment (A66734)
Unused 2020 Kodiak...
2015 Chevrolet Express Shuttle Bus (A66736)
2015 Chevrolet...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
