8' pull-type disk behind L5460, possible?
/ 8' pull-type disk behind L5460, possible? #41
I did throw the number out but it's not like I can actually know the exact amount to the ground.
I will for sure link the videos .
I'm basing my opinion off the way my 4060 struggles to pull the land plane. I think we can agree a land plane is no where near as hard to pull as a disk that's actually down in the soil.
I love my new tractor don't get me wrong but I don't see it as a good candidate for ground engagement type work. I bought it primarily for grass cutting / bush hogging type use.
/ 8' pull-type disk behind L5460, possible? #42
Agree, Chevy.
Way back at the beginning of this thread the OP stated that the 8' disc in question weighs 2,000 Lbs. That is not a light weight 8' disc.
SDT
/ 8' pull-type disk behind L5460, possible? #44
Ok here is a link to some videos I made today disking a area of my yard we're trying to reclaim.
What is the spacing between pans on prospective Disc Harrow?
Nebrfarmr
Veteran Advisor - Successful Farming
‎09-22-2011
Re: Disc spacing
We have both a 9" and 7 1/2" spaced disk, both are older IH disks, so they are built similarly.
9" disc spacing - goes deeper, pulls just a little easier for the depth you are going, doesn't plug. Usually with the wider spacing, you go with bigger blades. Chops through heavier residue easier.
Better for going deep, and burying some stalks.
7-1/2" disc spacing - smoother seedbeds, doesn't make as big of clods if the ground is a little wet, cuts stalks into smaller pieces, but will plug sooner in heavy trash. In wet conditions you better be sure the scrapers are in A-1 shape, at least on our soils. One pass with it on bean ground leaves the ground as smooth as 2 passes with the 9" spaced one. However, in heavy cornstalks, and deep ridges, it is hard to get it down deep enough to chop the stalks in the bottom of the ridge all the way through in tough conditions.
jeff9366
1/31/2019
Disc/Pan Spacing
My primary Disc Harrow objectives involve CUTTING; opening new game feed plots, maintaining vegetation free fire breaks and vegetation control along woodland trails. Harrow weight on 16 discs, rather than 20 discs, puts more cutting weight on each disc. Spacing between discs is 9". If you have rocky soil, 9" disc spacing will collect fewer rocks.
Tractor users with SMOOTHING (plow furrows) as their priority may consider the 20/18 or 20/20 configuration. Both have 7-1/2" spacing between discs.
Disc Harrows are available with two types of discs: notched and smooth. Notched discs cut pasture grass and crop stubble better; in open soil notched blades jerk out trash, meaning vines and tree roots, which sporadically stick in the notches. Smooth discs roll over some vegetation that notched discs cut through.
Sorry the tandem pull disc was 9" spacing with notched in front and smooth on rear with furrow filler.
Three Point Hitch mounted Tandem Disc Harrows have a significant proportion of implement weight supported by the tractor. This improves tractor traction. However, there is less pan weight on the ground so pan penetration is less.
Drawbar attached articulating towed Disc Harrows have all pan weight on ground so they cut better, which may be an advantage or disadvantage. A towed Disc Harrow with same weight and pan spacing will exert significantly more draft resistance force to the tractor, while there is less weight on the tractor, meaning tractor is more likely to lose traction.
Drawbar attached articulating towed Disc Harrows follow the ground better than TPH Disc Harrows unitized with the tractor. Not an overly valuable characteristic harrowing flat ground.
A transport Disc Harrow with hydraulically adjustable wheel height will vary pan penetration.
I am dubious an open-station L5460 has enough weight to pull an 8' pull-type, 22" pans x 24 pans coming in right about 2000lbs more than one pass through a sandy field. However, all my experience has been with TPH mounted Tandem Disc Harrows.
Is there a reason you are reluctant to use a 3 X 12" = 36" wide or 3 X 14" = 52" wide moldboard plow for primary tillage?
Then a 1,200 pound Disc Harrow with 7-1/2" (+/-) pan spacing for secondary tillage"?
How deep is your top soil? You do not want to mix top soil with infertile subsoil.
How many total acres do you wish to process in yearly segments?
My L3560 and your L5460 are close in bare tractor weight. I have air in L3560 rear tires, not liquid.
PERHAPS INTERESTING: Disc Harrow - TANDEM LIFT DISC HAROW, Monroe Tufline 18/20", TH971820B, REVIEW
Consider an APP/Field Cultivator for 10"+ depth. You do not want to mix top soil with infertile subsoil.
MORE: Dirt Dog - All Purpose Plow / Field Cultivator REVIEW + PICTURES
VIDEO: Fred Cain 7 Shank 3 Point Field Cultivator 85in bar
I guess my reason for not plowing prior is I will be purchasing a tiller and didn't really want another tillage implement to deal with. I realize that would would be the 1st proper operation.
This thread is a good example of what happens when you try and mix city people who buy a tractor with people who grew up around them.
Always an excuse for limitations....rather than real world experience.
Thanks for everyone who had something informative to contribute. Again I knew this disc was at the max end for my tractor but maybe wishing others had pulled it off with decent results. I figured the small amount of ground I need to work up per year maybe just maybe it could be done. This is the only ground engaging work I need to do with my tractor. Gotta get back to the city so thanks again!
/ 8' pull-type disk behind L5460, possible? #50
A lot depends on your soil type. A 7.5” blade spacing in my area would not go - plugs solid. Yours may be fine. Next blade diameter. You say 24” blades. The only disks I’ve seem here with 24” blades and 8” width are offset disks. They cut deep, pull hard, and would be anchors for your tractor unless you limited curing depth to very shallow. I used to borrow my cousin’s 10’ offset with 24” blades, worked well behind my 135 HP tractor. I used a 12’ disk with 18” blades behind my L5740 - properly sized but that was a disk my dad bought for our farm in 1958. It worked well with our 56 HP tractor at the time, and about the same with my L5740. But our soil needs to be moldboard plowed working with sod. Cropped the previous year will work with disking.
/ 8' pull-type disk behind L5460, possible? #51
If you purchase the disc, let us know how it works. I would like to purchase a disc at some point in the future. As you said a tiller is slow work.
/ 8' pull-type disk behind L5460, possible? #52
Honestly if your getting a tiller anyway why not get some type of chisel plow that would work behind your tractor just to loosen the soil up some then till ? It would probably be faster overall . Lots of times you have to go over the area multiple times to get the soil worked up how you want it with a disk. It's really not any faster.
/ 8' pull-type disk behind L5460, possible? #53
I think the issue will be TRACTION, not power. Your R4 tires will spin out if it's the least bit wet, but I think if the ground is perfectly dry for limited use you'll be fine.
If the ground is soft, your are not moving.
Hydro would be my other concern, but if you are not disking for days on end you are likely fine.
I pull a little 24 plate tandem drag disk, hair over 6 feet wide. It's old but it's paid for and has all new plates. 40 HP 2wd utility on 13.6-28s R1 will play with it when the ground it right. Old 25 HP gasoline 2wd used to pull one fine too.
I can pull it 8 MPH with 70 HP if I want and through almost anything.
I ran a 10 foot years ago behind an 85 HP FWA Deere. It was too much disk in the wet places, not enough in the dry.
/ 8' pull-type disk behind L5460, possible? #54
One thing obvious in your video and that is, you don't have the gangs splayed out at all. Crank the angle out and then report back. Discs don't disc when running parallel, they disc properly when they are angled out the more, the better.
I bet with the gangs splayed out correctly, you don't have enough arse to pull it anyway.
/ 8' pull-type disk behind L5460, possible? #55
Here's another video of my 4520 jd pulling the same disk in the same spot . Obviously the JD is about 10 more horsepower but it's also a gear drive tractor.
B range 4th gear.
/ 8' pull-type disk behind L5460, possible? #56
Study these two Monroe Tufline TPH Disc Harrows:
TL43 SERIES
TL43972222 - 8' - Pan Spacing 7-1/2"/9" - weight 1,475 pounds
TX4 HEAVY SERIES
T4X972222B - 8' - Pan Spacing 7-1/2"/9" - weight 1,591 pounds
Both of these "Big Ag" discs for compact tractors will require HST/MED and almost full or full throttle to pull at a good clip. You will appreciate your loaded rear tires pulling either Disc.
LINK: Agriculture | Tufline
/ 8' pull-type disk behind L5460, possible? #57
May just me but I'd also look at the Monro Tufline TW5 pull-behind series as well - the three point mounted will likely be cheaper, but having an implement close to 1/3 of the tractor's weight hanging off the back on a 3pt can get be rather noticeable if/when it swings from one side to the other while lifted.
I know it's definitely noticeable when the EA XTreme Duty Large Deluxe Box Frame Disc Harrow (ETA-XD-LG-BF-DH-20-18) shifts (when lifted) on my L3560. ...and since I think I forgot to mention it earlier I've got R4's on mine, and it is an HST.
So what you're looking to do is potentially run an 8' pull-behind disc on a 54-ish HP tractor across flat ground with sandy/loam soil -- or go about 14"/ 2 pans wider than I do across flat-ish clay/loam soil with tractor that's relatively similar in weight (a bit lighter with wheel weights vs loaded tires -- which may also be partially offset by difference in operator weight 😇) but almost 20hp less....
While neither is the ideal tractor (nor configured in the ideal way) for the task, I have a hard time the larger would be completely incapable given what I'm doing with mine .....
BTW - a hydraulic top link is useful thing when using a 3pt mounted disc as it will allow for changing the pitch of the disc on the go (which can be handy if/when you need to shift balance/pressure to get a better cut with the front gangs)
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
74" X 49" TAILGATE (A64280)
74" X 49" TAILGATE...
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
1999 John Deere 7810 (A60462)
1999 John Deere...
