3 phase converted to single phase
/ 3 phase converted to single phase #1
yanmars
How difficult/expensive to convert a 3 phase propane generator to single phase for home use? Would the transfer switch need to be changed also?
/ 3 phase converted to single phase #2
You need to derate the output. For instance if its a 20 kw the single phase output will be about 14 KW. Its not done very often. Some generators can be rewired in the stator can, some can’t. Need to check with manufacturer
/ 3 phase converted to single phase #3
Check with the manufacturer. I am not sure you need to do anything. If it is a 230V 3 Phase generator, you maybe able to just connect to two of the three wires to use for single phase power. This is what I would do coming off a 3 phase transformer. I am just not sure it is OK to do from a generator?
/ 3 phase converted to single phase #4
Ive seen it done, but its not recommended. Hard on an alternator. Not the same as a transformer. Better 3 phase units have wiring in stator can that can be swapped around to get single phase
/ 3 phase converted to single phase #5
Thanks. I wasn't sure if it would hurt a generator to have one phase not being used.
/ 3 phase converted to single phase #6
Do you plan to convert the generator to single phase or just use one phase of the three? The Cycle Stop Valve url has no bearing. If you elect to use a single phase of the three be advised that the single phase voltage may not be what you expect. You should consult with an electrician for your own safety and that of the equipment..
/ 3 phase converted to single phase #7
... If you elect to use a single phase of the three be advised that the single phase voltage may not be what you expect. You should consult with an electrician for your own safety and that of the equipment..
Ayup.
It is a Kohler unit if that helps any.
Model 20 RZ
/ 3 phase converted to single phase #11
I cant find any wiring diagram on the 20RZ, But I did find one on the 12RZ. It shows that it had a 12 wire stator that can be rewired to single phase pretty easily. But it will still derate generator by 33%. So a 20 kw unit will be a put 14 KW output.
But it should work.
http://www.sailing.com.br/loja/manual/17e22op.pdf
Thanks for that information
2019 KENWORTH T880 (A65643)
2019 KENWORTH T880...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
John Deere 1025R (A62177)
John Deere 1025R...
Metal John Deere Birdhouse (A64127)
Metal John Deere...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
