Your towing rigs and trailers
/ Your towing rigs and trailers #3,812
I think it's beneficial to debate these things, someone will learn something.
I agree, nothing wrong with a walk around the barn once in awhile, plus it relates to towing. Speaking of which, the little small block 5.9 Cummins equipped with an exhaust brake...the gassers better move over on the down hill....all mine are so equipped.
Now the 2.0 Ecoboost in my Ford Escape, I love it:)
/ Your towing rigs and trailers #3,813
That pretty much sums up what Ive been saying, but if someone wants to be convinced a 3L ecoboost is a tougher engine and a better choice in a truck that a 6.7L diesel, more power to him. :confused3::laughing:
The other one is just here to do his pot stirring.
It seems to me, your situation only dictates a need for a heavy duty truck, therefore all know how to do is recommend a heavy duty truck. That is easy to do as you've proved. There is no articulation, just ham fisted justifications.
For the vast majority, including me who has both an ecoboost and powerstroke, I would love something I could combine into one. An ecoboost has more than enough power to haul what I need, but the chassis is not up to the task.
Nuance is a lost art...
/ Your towing rigs and trailers #3,814
What would you be gaining to drop an ecoboost in a F-350 vs the new 7.3?
/ Your towing rigs and trailers #3,815
Maybe one day ford will make a 5.0 ecoboost and put it in a F350.
Problem solved.
/ Your towing rigs and trailers #3,816
Guess you conveniently skipped this post I wrote an hour ago in this thread. I think the other thing you keep forgetting is that it was you making the comparison between the thickness and strength of the ecoboost and the 6.7L Cummins. I simply responded that a 6.7 Cummins will work circles around an ecoboost and last longer doing it.
Seems like you dont take other points of view too well!!!!
/ Your towing rigs and trailers #3,817
I live in wyoming at 8,000 feet. You loose 3% of power for every 1,000 feet of elevation, I'm 24% down off the bat. The Ecoboost puts me back to square.
I waited years for a boosted production truck. Not something you have to part together to get. It's amazing to be able to be on the interstate in a 80mph head wind going up hill and not lug the motor. It's also amazing when I go skiing, to get that same performance I don't have to take my diesel, when I use to have to. It's a pain in the *** driving a diesel in a ski town, but I did and did it for years. Now I don't.
Things are different up in the thin air.
/ Your towing rigs and trailers #3,818
Seems like you don’t take opposing points of view too well!!!!
It does have stronger internals and bigger bearing surface area's. Look it up.
It's hard to follow your logic on that post. You say it makes no sense to buy a diesel if you don't tow a certain weight. OK. You say it makes no sense to buy a diesel if you don't drive a certain mileage per year and a high load. OK . You say the diesel will last longer. Ok.
But guess what I'm a buyer of a HD truck with non of those conditions. I'm also a buyer of a light duty truck with all those conditions.
So you're not talking to me there.
/ Your towing rigs and trailers #3,819
No reason to not believe what you say about stronger internals. You dont strike me as a liar or exaggerator. I would dispute the strength issue as an engine is an assembly and only as strong as its weakest link. That’s why a Cummins 6.7 is a medium duty engine with a far longer B rating than an ecoboost gas engine. So we are good there.
But to compare both engines, even if they were in the same truck, its lights out. The Cummins would do more work and last longer doing it.
The other reason a gas engine is not in a Cummins diesels league is its making almost full torque at about 1700 RPM. Gas engines much higher RPM and guzzling fuel.
/ Your towing rigs and trailers #3,820
Drop a turbo on the 7.3. Lol.
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Massey Ferguson 4610 (A60462)
Massey Ferguson...
Cat CB24B (A60462)
Cat CB24B (A60462)
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A60736)
2017 FORD F-150...
