I'm a Believer... No Not the Song... R4 Tire Grooving
   / I'm a Believer... No Not the Song... R4 Tire Grooving #1
LittleBill21
Elite Member
PA
Mahindra Max 26XL, White
First go around since I grooved the tires, big big difference, I don't know if the snow was different, it was definitely heavier, but significantly less trouble this time, almost 0 spinning and hills i needed diff lock and had to spin my way up, i went in reverse (no diff lock at all). To those of you debating, i would definitely do tire grooving before going chains to see if its enough. I am not buying chains now. (90 vs 800)
   / I'm a Believer... No Not the Song... R4 Tire Grooving #2
How long did it take you, and what groover / iron did you use? Looks like you did a great job. Contemplating doing my B2601.
   / I'm a Believer... No Not the Song... R4 Tire Grooving #4
I never thoght about the ATV, good idea.
   / I'm a Believer... No Not the Song... R4 Tire Grooving #5
Tire siping - same idea. I always had my big M/S tires siped on my Jeep. Jeep was light and siping REALLY helped in snow and ice. Local tire store - Les Schwab - has a special tool for siping.
the tool i listed above will do siping, you just need to turn the blade around. siping doesn't work apparently on tractor tires as they don't spin fast enough i guess to have any benefit, thus why tractors get grooved
   / I'm a Believer... No Not the Song... R4 Tire Grooving #7
I did the grooves last yr and it definitely makes a big difference and if your tires are rimgard loaded you will notice the difference.
I have washer fluid in all 4, and a BH hanging off the back. I was smashing frozen snow banks down like it was nothing in High.
   / I'm a Believer... No Not the Song... R4 Tire Grooving #9
I've seen that mentioned here before, how does it work? Not quite sure I understand how these shallow grooves work where the large lugged tires don't.
Simply gives the tire more biting surface into the snow, snow on snow causes friction, friction allows grip, i have effectively double the gripping force by adding this. at least thats the way it was explained to me. you definitely do notice a difference.
   / I'm a Believer... No Not the Song... R4 Tire Grooving #11
Any downside?
   / I'm a Believer... No Not the Song... R4 Tire Grooving #12
Any downside?
It weakens the tread abit and if you spun the tires really bad, it could tear a lug out. I dont see that happening on a tractor though
you would literally have to spin it on shale, very fast. i ride coal dumps with atv's which have similar grove patterns, we literally have to roast the tires (not possible on tractors) to really damage a tire, and even then you would have to do it a lot longer then any normal amount of spinning.
   / I'm a Believer... No Not the Song... R4 Tire Grooving #14
FWIW, I suspect it has something to do with a water film that may form under tire contact pressure- maybe like a mild form of why ice skates work so well. I DO know that my driveway's hill is a lot slicker as it warms up toward freezing. Figured the water film forms better then. So maybe the extra groove forms a reservoir or escape path for that water film that would otherwise have no place to go, especially on large contact areas like tractor tire lugs.
Wikipedia says it's for wet or slick surfaces:
Siping (rubber) - Wikipedia
   / I'm a Believer... No Not the Song... R4 Tire Grooving #15
Thanks for posting your experience. I have been considering adding studs as I am not willing to (and may not have the clearance) use chains.
This is a lot less expensive.
Has anyone tried it on turf tires?
   / I'm a Believer... No Not the Song... R4 Tire Grooving #16
Grooving does make a remarkable difference, especially on R4 tires.
   / I'm a Believer... No Not the Song... R4 Tire Grooving #17
X10 on grooved tires improving traction. I did all four on my previous tractor R4's. I have the rears grooved on my current R4's, and the difference is certainly noticeable.
If I ever get around to doing the fronts, I think I'll just do a single groove down the center of the lug, as on the rear.
   / I'm a Believer... No Not the Song... R4 Tire Grooving #18
Does this help at all when working in dirt /moist dirt / mud? I do not use my tractor often in the snow.
   / I'm a Believer... No Not the Song... R4 Tire Grooving #19
Sadly only R1 tires work best in mud..ask me how i know..lol Got mines stuck far too many times
   / I'm a Believer... No Not the Song... R4 Tire Grooving #20
View attachment 687436View attachment 687437
I knew you would like the grooved tires. They worked great in the snow I got here in Ohio.
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2014 GMC Sierra SLT Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
Booster Cables (A59230)
Booster Cables...
International 9200 (A56438)
International 9200...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2018 Chevy Traverse 3rd Row Seating (A56438)
2018 Chevy...
