Dirt Moving Box blade
/ Box blade #1
thunder86
Southern Indiana
Bobcat ct4045
How deep will a box blade dig a trench? I've a got a small creek that is spilling out into my field and flooding some of it. I want to dig s trench and run it to a major creek that runs along the other side of the property. Kubota b2601, southern Indiana. Also will the water just keep making this trench wider? Or deeper? If it goes deeper eventually it won't work as the major creek would just backflow. I have a lot of rock stone rocks and the field is 400 feet wide. Thanks.
/ Box blade #2
A box blade is not suitable for trenching!
/ Box blade #3
I would investigate something to keep the creek from flooding the field, instead of draining the field. Maybe place lots of your rocks, with some dirt, between the creek and field.
Bruce
/ Box blade #4
I'm thinking a subsoiler/middle buster would be your best bet. I would start and finish trench about a foot or so away each end making small passes until you get depth you want. Then finish the one foot so water goes through.
Pictures would help.
It could be you'd want it fairly deep, put a few inches #57 gravel, corrugated plastic drain pipe, gravel then dirt on top. 20210220_150109.jpg
/ Box blade
There's a culvert in the creek where someone put in years ago to keep it in the woods. The water flow is about 2 feet below this culvert and has washed out a sharp bend into the field. Not sure how I'd fix this and if I paid someone to dig the plastic culvert out it would probably get destroyed.
/ Box blade
Any idea how much gravel I'd need to go 400 feet long 1 foot deep? Drain tile being 4 inches I assume? Might be my cheapest route, pretty sure I know guys at my work with subsoilers.
/ Box blade #7
I buy a lot of 12 inch diameter 80 psi pvc pipe for less than $6/foot delivered to site. So 6x400 $2,400
That said You have not provided much information to help us help you. Need more info and pictures slopes maps.
/ Box blade #8
4" drain tile will plug easily with sticks and grass.
/ Box blade #9
Pictures would really help. And 4" is small.
There are gravel calculators. You wouldn't need this much since pipe take up room.20210221_201244.jpg
2020 CATERPILLAR 259D3 SKID STEER (A65056)
2020 CATERPILLAR...
2016 Ford Expedition SUV (A66738)
2016 Ford...
TIRE RACK WITH DIFFERENT SIZE TIRES/WHEELS (A67714)
TIRE RACK WITH...
KIVEL TRAILER MOVER ATTACHMENT (A64553)
KIVEL TRAILER...
1997 Ford Expedition 4X4 SUV (A66738)
1997 Ford...
2017 CATERPILLAR 980M WHEEL LOADER (A65056)
2017 CATERPILLAR...
