2015 Yukon XL
/ 2015 Yukon XL #1
deerefan
louisiana
1952 8N, 2005 JD 5103
After having a 3rd child and with needed space with 3 kids and farm/horse activities, we have decided to trade our 15 Armada for a 15 Yukon XL. It is a SLT with the 5.3. It has 85k miles. Great shape. Wife puts 8-10k miles a year on a vehicle. Last GM product we owned was a 2011 Silverado with the same motor. Can you guys provide pros and cons, especially mechanical, on the Yukon? As always, thanks in advance.
/ 2015 Yukon XL #2
If you know someone with a Consumer Reports subscription, that might be your best source for information.
Thousands of inputs on all sorts of vehicles!
/ 2015 Yukon XL #3
I own a yukon xl, 5.3 as a family vehicle. Owned mostly Chevrolet trucks before. We like the yukon for all we do. Most missed throwing stuff over side of truck bed. Great family hauling unit. I can haul stuff without getting wet. Lots of people when needed.Tows well light duty. If you intend pulling heavy,would suggest 6.0 engine,great power difference pulling. My past experience with this engine as been good over the years. I have had several trucks with 5.3 engine no major issues. I do pull a dual axle landscape trailer as well as a 16ft foot easily with it. Hope that helps . I'm sure there are others with pros and cons this is what I experienced.
/ 2015 Yukon XL #4
Keeping your stuff dry and a lot more theft resistant over an open bed truck is great. I had a 2500 suburban and now a Ford excursion because I needed more towing capacity than a half ton.
/ 2015 Yukon XL #5
Ive had numerous 5.3's over the years and never had a problem with any of them. Maintain them and they will serve you well. The only real full size SUV issues I've run into are the front wheel bearings need replaced sometimes--hit/miss there.
/ 2015 Yukon XL #6
just about bullet proof, but if there is a problem, generally cheap and easy to fix in your driveway. example: a wheel bearing can be done in an hour and costs about 100 bucks. probably less if its not your first time.
/ 2015 Yukon XL
Thanks everyone . We picked it up today, 2015 SLT XL. Very clean. 5.3, 3.08 gears 2wd. Won’t tow often, maybe 3-5 times a year, 5-6k lbs max. With 3 kids, we outgrew the Armada. IMG_2767.JPGIMG_2768.JPGIMG_2769.JPG
/ 2015 Yukon XL #8
The 2011 5.3 you had was different than a 2015 5.3L, the new one is direct injected and almost everything is different but rod bearings... but that doesn't change that it is a great engine like the LS 5.3L, the main downside of the direct injected engines is the EGR and crank vent sludge eventually caking on the intake valves and the fuel injectors don't spray gas on the valves to clean them off...
/ 2015 Yukon XL
Is there a additive, like marvel mystery oil for example, that you can add to the crankcase to help this?
/ 2015 Yukon XL #10
drive it hard. the 5.3 DI does not have this issue near as bad as many other models, and I believe if you drive it a little harder that the valves with get hotter and burn it off better. I have 110k on my 15 sierra and it runs like a top / does not burn a drop of oil.
/ 2015 Yukon XL #11
You can simply add Techron fuel treatment to the fuel tank every 5/10,000 miles, in the proper concentration. This will help with the valve contamination as well the injectors
/ 2015 Yukon XL #12
fuel additives do not help with carbon buildup on the valve in a DI engine.
/ 2015 Yukon XL #13
Agreed, My 16 Sierra never used a drop of oil...Those motors like to be run, not baby'd.
/ 2015 Yukon XL #15
The more highway the better I believe, my boss has a '14 Silverado with the 6.2L DI and it's been good to go with 150K or so on it, somehow it bent a pushrod a couple months ago but still ran just had a tick, they thought a rocker was breaking down or something, tearing down getting ready for a rebuild and was just a pushrod. Like said, the more highway and driving the better, if it's stuck in city traffic at idle a lot it might have more issues. Another coworker has a Malibu with a V6 DI of some form and it has close to 200k on it and no engine troubles...
/ 2015 Yukon XL #16
I had a suburban with a 6.0 with over 300k. The rear main was pouring but besides that no problems.
/ 2015 Yukon XL #17
Well...
We have a Malibu (4 cylinder) and an Impala (6 cylinder), both with GDI, and both failed catastrophically. They were unrepairable and had to be replaced. Digging into the dead engines, the backs of the valves were completely coated with carbon. Was that a contributing factor to the failures? We'll never know. Both have variable valve timing, and both had failed cam sequencers. At some point, the timing was so far off that they both slammed valves into the pistons, metal flies, and POOF! As to what happened first to cause the eventual timing system failure, again, we'll never know.
Our mechanic says GM recommends periodically cleaning the intake valves using their top engine cleaner. He says when he did it the first time, he thought he killed his engine, it smokes and shudders for about 25 minutes. However, it appears to work and he did it to both of our engine replacements, and will do it every few oil changes.
So, just be aware of that potential issue, and it's a recommended maintenance item, so it should probably be done at the recommended intervals.
/ 2015 Yukon XL #18
Those 6.0s will last forever. Mines at 230k currently. Never moves unless it’s towing.
/ 2015 Yukon XL #19
Those 6.0s will last forever. Mines at 230k currently. Never moves unless it痴 towing.
My 1997 GMC 2500 Suburban has the 454V-8 (7.4L).
It will tow ANYTHING!
It has only 130K, and is stored in my barn now,... because I have no use for it.
Can't quite bear to sell it yet though.
Maybe E-Bay this Summer ???
/ 2015 Yukon XL #20
Well...
Have you seen that done Moss ? Just wondering how that top cleaner gets administered.....
Rgds, D.
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2716SFL (A61567)
2716SFL (A61567)
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
