monolitic slab
   / monolitic slab #1
yanmars
I have a two story building sitting on a 26x36 monolitic slab built this way. All top soil removed, maybe 14 to 16 inches. Then compacted the soil. They about 9 inches of clean gravel added and compacted. Then moisture barrier of plastic. Then rebar and mesh and 7 inches of good grade concrete added. Then sealed with Thourglaze after cutting the concrete to avoid cracking.
Then three high split face blocks and 2x6 construction on the first floor. 2x10 on the second floor in a mansard style. Have a lean to in additon on one end and a raised two story deck on the other. The floor joist on the first floor are 2x10 and on the rafters on the second 2x8. All on 16 inch centers. On the first floor three 2x10s as a beam supporting the second floor on the length, two cross beams under that and those supported by steel posts.
It has been there 23 years and concrete and blocks are good, one hairline crack of about two feet. No heaving, spalling etc. Live in Ohio.
I would like now to turn it into a hunting/vacation cabin for the kids. Add water, electric, heat etc. Bedrooms on second floor for kids. Used occasionally.
Now need zoning permits. It appears they are concerned about frost heave. Never had any so far. Initially they say I will have to excavate the entire perimeter 32 inches deep and put foam insulation up against the same. I should have mentioned that the concrete is 7 inches everywhere except for deeper areas under where the steel supporting posts are.
I have concerns if I excavate to 32 inches the gravel will to some degree come out and leave the concrete to some degree unsupported at that point. It also will be considerable expense and difficult at the deck and somewhat at the lean to. Was wondering if horizontal foam of 6 inches thick might work and even that poses some problems if it has to be covered by 10 inches of dirt.
I would have thought once heat was added to the building there would be less chance of heaving but perhaps not and more.
I am not opposed to the thought of perimeter insulation being good but it will be a difficult procedure at best. Would prefer to use EPS (Exterior Poly Shield) vs. XPS if that is acceptable.
Just hoping there is some way to do this that will work and still meet code. It is an ag storage building now and needed no permits but does if there will be any human overnight use.
Thoughts or guidance are appreciated. Thanks
   / monolitic slab #2
Foam at a depth deeper than the concrete is doing nothing. Any competent inspector should know this. I question their requirement in the first place, foam on the outside of the slab doesn't do much. Foam is for under the slab as a thermal break between the ground temperature and the slab. On a basement it makes sense, but not on a monolithic pour.
I wouldn't dig deeper than the bottom of the concrete and just put foam on concrete only. Then hope you get a competent inspector.
   / monolitic slab #3
I would suggest their thought was the surface foam would keep the cold from penetrating to heave the footing. The building being heated would pass warm to below and not allow frost below. Why after 23 years of not heaving, but there are code rules. I would try to get an exemption. Approach from a type of soil that apparently does not hold much water, or you would have had damage.
   / monolitic slab #4
Mostly I'm commenting to follow the thread and see what you end up doing, but I am also surprised that you need a permit to remodel an existing building. Every state is different, and I'm fortunate to live in a state that lets you do what you want with your land and buildings without dealing with permits. I realize that it's too late now, but what would have happened if you had just done the work to the building without telling anybody?
When I lived in CA, they where crazy about permits. Anything over $100 required a permit. This led to very few people getting permits, and a lot of work being done under the table. When you sold a house, you just declared that no permit was obtained for the work on the house, and it was up to the buyer to walk away or accept that. It might be different now, but building inspectors where overwhelmed with new construction work to bother with remodels and additions. If a contractor went through the permit process, he had to add all those fees to the cost of the job, along with downtime waiting for the inspection. Everyone that I knew just hired whoever was able to get the job done, and nobody had a Contractors License, or bothered with permits. The cost difference between doing it legal and how most of it gets done was double!!!
   / monolitic slab
For ag buildings almost no regs or permits needed. For people buildings many, many needed. The Amish live near me and they did a number of building, remodels etc. and got in hot water over the same. Red flagged and cease and desist orders.
I am afraid if I did anything like that I would have had to tear everything out or uncover, redig everything to show compliance. I think it could get complicated if not expensive. We shall see.
   / monolitic slab #6
Since you already spoke to the government, you dont have any choice but.to do it their way.
   / monolitic slab #7
For ag buildings almost no regs or permits needed. For people buildings many, many needed. . .
Not true in a lot, if not most, places. One reason for requiring permits is to facilitate taxing its value, even if its only an ag building.
   / monolitic slab #8
In many states the real estate laws require a residential seller to disclose any improvements and that work was none by licensed mechanics etc...some states/municipalities will give waivers for qualified homeowners to pull their own permits for some of the work but some trades like plumbing, elec, AC/heat etc...often require licensed companies...
Another factor in some places is insurance requirements...if a homeowner puts an addition on their house and does all the work them self...including plumbing, elec etc...they may or may not be able to get insurance on the improvement without affidavits from licensed tradesmen saying the work is up to code etc...
   / monolitic slab #9
Horizontal foam will protect the soils beneath it. It helps hold the heat in and will help to protect from frost penetrating beneath the edges of the slab. I have done it and it works well.
You are also right that if you excavate along the edge of the slab, you may loose a bit of soil and gravel. Depending on the soil type this could be very minor or cause a cantilever situation in which your slab is not designed to handle.
   / monolitic slab #10
asinine concept to put insulation in a perimeter location either way. If not up against a solid surface like a basement, it is both worthless and I wouldn't do in this situation. It will be what is heaved.
   / monolitic slab #11
Here assaten fer ya. Frost starts on top of ground moves across top of ground den goes down. You got dirt tight up to slab. WHAT stops cold goin into side of slab from dirt if you not frost fence?
You want 11? Heat rises. How ground under slab get cold to start? Gotta come from outside after goes down.
Object de game is to make slab thermal battery.
   / monolitic slab #12
Not really...Hot air rises but heat moves from hot to cold...
   / monolitic slab #13
You know Slushi I really like to help you wid understandin BTU in motion, and thermal battery along wid heat transfer betwixt different materials, but you not up to de task.
Probably best you run along back to peein on yer sock an sniffin to see if you makin de turpentine.
   / monolitic slab #14
How do you say idiot in your pidgin?
   / monolitic slab #15
You said "heat rises"...it doesn't, get over it...your analysis may be spot on but your statement is utterly false...
LoL...Heat transfer is hardly brain surgery or rocket science...:laughing:... It's those basic theories that you learn early that stick with you...and heat still moves from hot to cold (at least on this planet) all day and all night...one more time so maybe you'll get it...Hot air rises...Heat moves from hot to cold...! you should do one of your google searches to learn about heat sinks etc...! :laughing:
BTW, FYI I'm a profound student of the laws of thermodynamics...!
   / monolitic slab #16
/pine is correct. Heat moves in any direction due to thermodynamic principles and hot air rises because of a change in density. You can have one without the other; they are entirely diffferent mechanisms.
rScotty
   / monolitic slab #17
I deal with building departments all the time with my day job. Some inspectors only know what's on paper and only allow what's written by the lawyers who must have been paid by the word. Ideally you would have put insulation under the slab, because as /Pine stated, the cold ground will pull the heat out of the slab. Now if you can furr up the floor with joists and insulate between, that's different, unless you will only have living space on the second floor? Also keep in mind, bedrooms and habitable spaces need proper egress, not to mention smoke detectors, and if above the garage, CO2 detectors. Know any engineers that might prepare a letter to the building Dept to state that it's of solid construction and adequate? Sometimes inspectors just want their hind quarters covered, don't want to be at fault should it fail, then it's on them.
   / monolitic slab
Yes I wish I would have put rigid foam underneath but I did not. To the bottom of the floor joists supporting the second story from the concrete floor is a bit over 10 feet. I guess I could place EPS foam on the floor (they have some that support 40 or 60 psi. I could pour concrete over that or put wooden floor joist in and add the rigid foam between the joists. Kind of like tall sleepers. I have two standard entry doors but it would not be hard to remove them and change the opening. The stairwell would be a problem unless I made the new floor at finish the same height as the first step. It would be even with it and effectively gone but then all the steps would be of uniform height. It is a steel stairway.
I am really open to all suggestions. Will have to see what they require. Maybe rafters on the floor may be the way to go. The floor would then be insulated. Maybe some room for duct work or lines depending on which was the rafters would be ran. If so if one isolated the joists with a moisture barrier could FPS wood be used or treated.
I like this site. A lot of minds with ideas and experience.
   / monolitic slab #19
You real sure you want to lock dat position in Slushy? I give you time to think on it.
   / monolitic slab #20
In 21st Century Cajun we say "Thall303" fer de word idiot.
Thanks fer askin rather den jumpin off on stupid path.
Always glad to help language impared folks.
3410 (A47477)
3410 (A47477)
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
VOLVO ECR25 EXCAVATOR (A60429)
VOLVO ECR25...
