Texasmark
Elite Member
- Joined
- Apr 24, 2012
- Messages
- 3,762
- Location
- N. Texas
- Tractor
- Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
I have the 1" thick, comprehensive Owner's Manual but this isn't covered specifically. The manual covers the fact that On position is also Pre-heat position, and mentions an indicator in the dash panel but not this specific question.
My precious tractors had a dash "Pre-heat" symbol illuminate when the operate switch was moved to the ON position from OFF when the temperature was below a certain value. The light was timed and when extinguished, you roll on over to Start and go.
The MT225s just winks at you when going to the Pre-heat position my first morning in having it and in trying to start it, it winked at me when going to On position rather than stayed illuminated. I figured I didn't need to wait since it extinguished, rolled over to Start and it took several 2-3 second start-wait-start-wait cycles before the engine came online.
Question is, is it normal to wink and you just guess at how long the key stays in the On position before your roll on over to Start?
Operators manual states that idle RPMs on Hydros (my first tractor, my mowers are hydros) are over 1200. Mine idles at around 1600. Said it needed to be high to get the oil flow adequate to have decent performance at lowest speed. Yes, no?
Comments appreciated.
